ls /vtec oil squiter jets..
no waaaaaaaay. there are no holes for them to blot in the block. it goes the same for b20 blocks.
i work at a machine shop and i was trying to design something that will work with an h22 valve bolt to open oil passage of costum made squirters that will be bolted to the block. it might work but its too much work.
most people just use aftermarket pistons to get away with the heat problems. if you dont your rings on oem pistons wont last long. i'm talking from experience cause my friends Ls/vtec with type-r pistons only lasted 15k before it started to burn oil
RYNO48
Dec 6, 2007 10:43 AM
CrazyCiv
Feb 19, 2004 12:31 PM
internet ay
Sep 12, 2003 09:10 PM
