DelSol S B16A3 Swap Question...
Old Nov 5, 2003 | 06:57 AM
Immortal Sol's Avatar
Default DelSol S B16A3 Swap Question...
Is a B16A3 bolt in... Or will it require new engine mounts... And how much would it be for a full swap... Engine/Tranny and anything else i would need...
I did search but couldnt find out if i would need new engine mounts...
Thnx...
Old Nov 5, 2003 | 07:04 AM
dohcvtecsol's Avatar
Default Re: DelSol S B16A3 Swap Question... (Immortal Sol)
well b16a3 cam e stock in delsols i got one in my delsol si and it bolted right in with no problem so as far as i know it should bolt rite into your delsol as well
Old Nov 5, 2003 | 07:08 AM
Hmm.... Did the Si come with a D16 or B16... The S that i have comes with a D15... So i was unsure if the B Series would bolt in...
Old Nov 5, 2003 | 07:11 AM
zer0.'s Avatar
i think you'll need a 94+ integra passenger side motor mount.
Old Nov 5, 2003 | 08:18 AM
Dr Honda's Avatar
The S had the D15... the Si had the D16 VTEC... and the VTEC had the B16a3.
don't know if the DOHC engine is a drop in though.
Old Nov 5, 2003 | 09:38 AM
salbaje's Avatar
yes direct drop in
Old Nov 5, 2003 | 09:39 AM
salbaje's Avatar
you will need b series mounts
Old Nov 5, 2003 | 09:48 AM
Phaze2 Mike's Avatar
Default Re: DelSol S B16A3 Swap Question... (salbaje)
If its a complete a3 swap then the ONLY place it came from was a USDM delsol VTEC. If its without mounts, get the 94-01 teg mounts. If without linkages, get the 94-97 Delsol VTEC ones <~ only stock ones that will work
Old Nov 5, 2003 | 09:50 AM
mathusala's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Immortal Sol &raquo;</TD></TR><TR><TD CLASS="quote">Is a B16A3 bolt in... Or will it require new engine mounts... And how much would it be for a full swap... Engine/Tranny and anything else i would need...
Thnx...</TD></TR></TABLE>
it would be a full swap, swaping a b-series into an s (eg1) is just like any other eg (except the for the eg2).
MeCrObS
Feb 1, 2019 02:49 PM
DaveRich
Jun 12, 2012 01:55 PM
ek9child
Jun 11, 2007 07:12 AM
d15b
Jul 28, 2004 06:41 PM
phantom_sol
Nov 19, 2003 11:28 AM
