JDM H22 red top with m2u4 trans. Is this the 220 hp ver ?
Old Nov 5, 2003 | 05:51 AM
JMI's Avatar
JMI
Default JDM H22 red top with m2u4 trans. Is this the 220 hp ver ?
We thought it was then we have had some customers tell us that it is not.
Also does the m2u4 trans make it a more difficult swap ?
Thanks for the info.
Derek of JMI
Old Nov 5, 2003 | 08:43 AM
Nick M's Avatar
Default Re: JDM H22 red top with m2u4 trans. Is this the 220 hp ver ? (JMI)
do u mean m2A4?
there is no 220hp version of any h22a, the highest rated they were ever released in the world was 220ps or 217hp
Old Nov 5, 2003 | 08:58 AM
JMI's Avatar
JMI
Default Re: JDM H22 red top with m2u4 trans. Is this the 220 hp ver ? (Nick M)
Nope it's m2u4. I found this on the web...
"The only H22 to avoid is from the Type SH Prelude. The brilliant torque distribution system (an electronically controlled box of clutches bolted to the block that Honda calls ATTS) replaces the intermediate shaft and its mounting bracket. The engine and transmission code to avoid is H22A4 and M2U4, respectively. Again, when someone actually swaps this in functionally, let us know."
Thanks,
Derek of JMI
Old Nov 5, 2003 | 09:05 AM
v4lu3s's Avatar
RTFM
the m2u4 is found in both the type-s and type-s as far as i know. currently not much has been said or done about putting it into a NON atts equippped car.
slap another tranny on it and sell it or sell teh atts equipped swap complete to someone who has an sh that is tired...
Old Nov 5, 2003 | 10:31 AM
accordm3's Avatar
the type s engine from japan has an atts transmission just like the usdm type sh. It also has a factory lsd on it. I believe the codes are the same on the transmission... look through the differential and see if there is a bar going through it... if there is then its not a type s... if there isnt then that means it has lsd
Old Nov 5, 2003 | 12:50 PM
JMI's Avatar
JMI
Yes it has the LSD.
On the the motor from is this the 217HP motor ?
Does the ATTS use the ECU ? OR is it tied in to the ABS system ECU ?
Old Nov 5, 2003 | 03:44 PM
satan_srv's Avatar
Default Re: (JMI)
ummm no the M2U4 does not have LSD, the ATTS system controls the differential.
Anyways if it has an M2U4, the the block code is H22A, with no numbers, the block head has a P5P stamp on it. and the Throttle body is 62mm, it's probably a type-s
Old Nov 5, 2003 | 05:03 PM
JMI's Avatar
JMI
hmm OK thanks I thought I it had the LSD. I'll look for the P5P stamp
To use the ATTS system what do you need ?
Thanks,
Derek of JMI
Old Nov 5, 2003 | 05:46 PM
satan_srv's Avatar
Default Re: (JMI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMI &raquo;</TD></TR><TR><TD CLASS="quote">hmm OK thanks I thought I it had the LSD. I'll look for the P5P stamp
Thanks,
Derek of JMI
You need a Prelude SH...bascially. It's virtually impossible to have a functional ATTS system on a swap...too many sensors/controllers/computers/suspension components. Either it goes in an SH or you have to do a custom fab base tranny swap.
Old Nov 5, 2003 | 06:05 PM
v4lu3s's Avatar
RTFM
in addition to the transmission you would need the ATTS unit (i have one in my garage right now) as well as the various sensors, specialized suspnesion components and computer to control it.
Old Nov 6, 2003 | 03:11 AM
JMI's Avatar
JMI
Ok thanks to all. Sounds like we will be spliting up the package.
Old Nov 8, 2003 | 06:11 PM
accordm3's Avatar
I am pretty sure about this... willie would know... that the jdm type s is lsd as well as atts
Old Nov 8, 2003 | 09:14 PM
satan_srv's Avatar
Default Re: (JMI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMI &raquo;</TD></TR><TR><TD CLASS="quote">Ok thanks to all. Sounds like we will be spliting up the package.
Realize that base trannies do not bolt to a type-s block without custom fabrication. But I think you'll figure it out when you try to put one on.
Old Nov 9, 2003 | 11:17 AM
Mikeyslude's Avatar
Default Re: (accordm3)
The Type S is ATTS no LSD. There is an S-Spec & SiR that has LSD.
Modified by Mikeyslude at 3:49 PM 11/9/2003
Old Nov 9, 2003 | 11:54 AM
Downey's Avatar
Default Re: (Mikeyslude)
Type S and Type SH are M2U4.. ATTS trannys, NO lsd
SiR spec or S-Spec are T2W4.. Both have lsd.
dc2 specR
Aug 19, 2016 05:19 AM
99 prelude sh
Mar 11, 2006 08:12 AM
LoganMantits
Jun 7, 2005 01:30 PM
Lan
Jun 6, 2005 05:39 AM
Jonathan_ED3
Jun 10, 2002 08:42 PM
