Will H4 bulbs fit in H4H headlights?
Old Nov 5, 2003 | 01:44 AM
E-lude78's Avatar
Default Will H4 bulbs fit in H4H headlights?
I have the SiR headlights and I want to install H4 HIDs. Can anyone inform me? Thanks.
Old Nov 5, 2003 | 03:44 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: Will H4 bulbs fit in H4H headlights? (Mista B-one-seven)
No period
the H4H bulbs are smaller in size and a heck of a lot harder to purchase
Old Nov 16, 2003 | 11:03 PM
E-lude78's Avatar
Default Re: Will H4 bulbs fit in H4H headlights? (ImsorryHonda-tech)
looks like i'll just have to get super white h4h bulbs...so much for HIDing the SiR lights.
Old Nov 18, 2003 | 03:40 PM
EFGeeSeR's Avatar
I used h4s in my SiR lights they fit w no filing, ijust dont know how to adjust the angle of the beam, if u figure it out let me know but h4s will work
Old Nov 18, 2003 | 05:06 PM
fourthgenhatchB17's Avatar
Default Re: (EFGeeSeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFGeeSeR &raquo;</TD></TR><TR><TD CLASS="quote">I used h4s in my SiR lights they fit w no filing, ijust dont know how to adjust the angle of the beam, if u figure it out let me know but h4s will work</TD></TR></TABLE>
I also got my HID 9006 set up to work in the SIR housings. To adjust the beam, there is a screw on the rear of the headlight bucket on the outside and there is another screw on the inner end of the headlight. By "outside" i mean near the corner light and by "inside" i mean closest to the radiator cap. basically just look on the back of the housings and look for a total of two screws, one on each end, and turn them and you'll see how it works.
Old Nov 18, 2003 | 06:35 PM
bryant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista B-one-seven &raquo;</TD></TR><TR><TD CLASS="quote">looks like i'll just have to get super white h4h bulbs...so much for HIDing the SiR lights. </TD></TR></TABLE>
H4's will fit into H4H's just takes some cutting to do and they work just fine.
Also you can get HID into H4H's you just need to do some cutting.
Old Nov 18, 2003 | 11:22 PM
E-lude78's Avatar
Default Re: Will H4 bulbs fit in H4H headlights? (Bryant)
I'm confused now. Some people are saying you can fit the H4 bulb with no mods, some say you need to do a bit of filing to fit it.
Old Nov 19, 2003 | 04:04 AM
bryant's Avatar
H4H are smaller then H4, thats why you have to do the cutting.
Old Nov 20, 2003 | 06:35 PM
You ppl can use the HID kit for the 9006 housings and they work fine. Its what i did with my SIR housings and the lighting is excellent.
Old Nov 20, 2003 | 07:25 PM
bryant's Avatar
Default Re: Will H4 bulbs fit in H4H headlights? (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">You ppl can use the HID kit for the 9006 housings and they work fine. Its what i did with my SIR housings and the lighting is excellent.</TD></TR></TABLE>
You have pictures of your beam pattern?
Old Nov 20, 2003 | 11:37 PM
E-lude78's Avatar
i'd also like to see the beam pattern and how you modified the SiR housings to fit the 9006 bulbs
Old Nov 20, 2003 | 11:51 PM
EF-9SiR's Avatar
i'd also like to see the beam pattern and how you modified the SiR housings to fit the 9006 bulbs</TD></TR></TABLE>
me 3!
Old Nov 21, 2003 | 02:37 PM
temp's Avatar
Default Re: Will H4 bulbs fit in H4H headlights? (EF-9SiR)
me 4
Old Nov 21, 2003 | 03:30 PM
4drEF's Avatar
Keyboard Humorist
This is going to need some proof. Without mods like gluing in a big piece of plastic I don't think this can be done. The H4H leaves a BIG hole in the housing if you remove it. The 9006 can be moddified to fit a USDM housing with a little dremel action, but I can't see how in the world it would come close to fitting an H4H hole.
Old Nov 21, 2003 | 07:11 PM
I have no clue how to post pics (plus my car is getting painted right now) but i definitely got them to work. I am very meticulous when it comes to my car so i really didnt want to make it too ghetto of an install. But i did want to reuse the 9006 HID kit because i had them already for my USDM housings and i wasnt going to buy HID's again. What i did was trim the 3 small little legs (i guess u can call them that) on the bulb itself (the legs on the HID bulbs are made of a hard plastic and they trim off very easily). I trimmed them off to get them to sit more inside the JDM bulb housings. From what i remember the legs on the 9006 lights are used to keep the bulb in place on the 9006 housings. If u dont trim those off the bulb itself, then yes it will not fit in the JDM housings. U must also remember that the regular halogen bulb DOES NOT physically look the same as the HID 9006 bulb, so dont try experimenting by trimming to fit the halogen bulb to the JDM housing. The HID bulb is also shaped in a way that it makes it easier to fit the JDM housing. I even reused the rubber bulb cover to keep dust/dirt/moisture out of the housings. About the beams, i had adjusted them PERFECTLY so they distribute light evenly and level. BTW i had to adjust the housings more downward due to the fact that the HIDS are really bright. If someone wants, i can email the pics to whoever and they can post them for me, but i have to wait to get my car back. Let me know who wants to do it, if anyone. I hope i shedded some kind of light on this subject to help you doubters out there understand the how-to.
Old Nov 24, 2003 | 06:16 AM
temp's Avatar
post pix when your car gets back
Ldo
Sep 24, 2008 11:58 AM
shortgeareddb8
Aug 25, 2008 04:33 PM
bopbop93030
Apr 4, 2008 01:40 AM
Eagle16nam
Jul 27, 2006 05:10 AM
Spaceballsthelunchbox
Dec 27, 2002 09:01 PM
