b20b or b20z bored out..... did search
Old Nov 4, 2003 | 11:59 PM
LSVTECoupe's Avatar
Default b20b or b20z bored out..... did search
whats the largest size you can bore a b20 block safely WITHOUT resleeving??
Old Nov 5, 2003 | 06:53 AM
KRiS1's Avatar
Default Re: b20b or b20z bored out..... did search (LSVTECoupe)
same as any other b-series block 85/86
why not just use a LS block instead?
Old Nov 6, 2003 | 06:26 PM
StorminMatt's Avatar
Default Re: b20b or b20z bored out..... did search (KRiS1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KRiS1 &raquo;</TD></TR><TR><TD CLASS="quote">same as any other b-series block 85/86
why not just use a LS block instead?</TD></TR></TABLE>
But not without resleeving. Without resleeving, 84.5mm would probably be as large as you want to go.
Old Nov 6, 2003 | 06:48 PM
KRiS1's Avatar
Default Re: b20b or b20z bored out..... did search (StorminMatt)
oops
I didnt see the giant WITHOUT resleeving
on me
Id say .5 over
Old Nov 17, 2003 | 01:39 PM
dwchkypmp20's Avatar
if i plan to sleeve my b20z can i bor it to a 2.2? please help me
Old Nov 17, 2003 | 03:19 PM
HONDABROMANDUDE's Avatar
Default Re: b20b or b20z bored out..... did search (dwchkypmp20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwchkypmp20 &raquo;</TD></TR><TR><TD CLASS="quote">if i plan to sleeve my b20z can i bor it to a 2.2? please help me</TD></TR></TABLE>No, you would also need to stroke it to get that much displacement.
Old Nov 19, 2003 | 11:59 AM
joacim's Avatar
Default Re: b20b or b20z bored out..... did search (itec311)
i need some info to i bre my b20z to 85mm stock sleves ,i am gointo use block guard and type r girdlle.and endyn struted pistons longer rod to have a better r/s ratio almost like a gsr. i my machine everybody says that if i plan to go all motor i will not goint to broke the block. but thats it more than 85mm is another thing
raidacaipo
10
Oct 7, 2008 12:46 PM
hammergunner
11
Sep 18, 2008 04:20 PM
EH3SiGRL
Nov 8, 2006 08:44 PM
No
May 1, 2005 06:45 AM
turbodGSR
Apr 27, 2003 09:00 AM
