building motor from scratch
Old Nov 4, 2003 | 11:46 PM
HKJ's Avatar
HKJ
Default building motor from scratch (searched)
alright guys, i've decide to build my motor peice by peice, so far all i have is the block, (ge sleeved 85mm b18c1) and a head, (gsr head, pnp, jun3 cams, jun retainers, jun valves, and jun cam gears) with a tranny, rods, and pistons on the way. i know there's plenty of things i'm missing.
just wanted to know if there's a checklist out there with all the necessary oem parts (seals, oil pan, etc) needed for the build up -- maybe even a scan from the helms would be sufficent. thanks
Old Nov 5, 2003 | 08:22 AM
owen_the_soyboy's Avatar
Default Re: building motor from scratch (HKJ)
http://www.acuraautomotiveparts.org has good diagrams but the parts can be expensive from dealers so get used stuff online here if at all possible
Old Nov 5, 2003 | 08:34 AM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HKJ &raquo;</TD></TR><TR><TD CLASS="quote">alright guys, i've decide to build my motor peice by peice, so far all i have is the block, (ge sleeved 85mm b18c1) and a head, (gsr head, pnp, jun3 cams, jun retainers, jun valves, and jun cam gears) with a tranny, rods, and pistons on the way. i know there's plenty of things i'm missing.
just wanted to know if there's a checklist out there with all the necessary oem parts (seals, oil pan, etc) needed for the build up -- maybe even a scan from the helms would be sufficent. thanks </TD></TR></TABLE>
A bit off topic, but things will get expensive, quickly. Take whatever number you expect to spend and double it. That's probably what you'll end up spending. Same thing happened to me...
Old Nov 5, 2003 | 09:25 AM
lsvtec hatch05's Avatar
Default Re: building motor from scratch (arw321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arw321 &raquo;</TD></TR><TR><TD CLASS="quote">
same **** happened to me, i have spent over double what i expected/ wanted to
Old Nov 5, 2003 | 10:44 AM
arw321's Avatar
Default Re: building motor from scratch (lsvtec hatch05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec hatch05 &raquo;</TD></TR><TR><TD CLASS="quote">
same **** happened to me, i have spent over double what i expected/ wanted to</TD></TR></TABLE>
"Well, it's only another few hundred dollars..."
I caught myself saying that so many times, lol.
Old Nov 5, 2003 | 01:11 PM
snowseeker's Avatar
My build was sposed to be around 2500.00 By the time I got to drive the car it was 6,000.00....
Old Nov 5, 2003 | 04:24 PM
HKJ's Avatar
HKJ
Default Re: building motor from scratch (snowseeker)
isn't there some parts i CAN reuse? like a used crank, oil pan etc etc, but then there's parts that shouldn't be used too, am i right?
at anyrate, i'm going to spend about 4300CDN on the block and head alone, and planning on spending another 3 for the misc parts -- it's already getting expensive quick.
DA9tothewheel
Nov 21, 2016 11:31 PM
team_Jesus808
May 30, 2012 01:32 PM
HatchSi
25
Jun 17, 2006 05:43 AM
hovic
Sep 12, 2004 03:48 AM
IEATLINT
Dec 10, 2003 10:33 AM
