b16a idle problem
Old Nov 4, 2003 | 09:38 PM
b16acrxer's Avatar
Default b16a idle problem
my idle fluctuates steadily from 750-1800 up and down up and down up and down...very steady. what causes this?
Old Nov 4, 2003 | 09:51 PM
Malgerus's Avatar
Default Re: b16a idle problem (b16acrxer)
A gigantic air leak. Vacuum leak or gasket leak, for example.
Old Nov 4, 2003 | 10:26 PM
VAAJ's Avatar
Default Re: b16a idle problem (Mr. S)
check for air pockets in your cooling system. also check to make sure your IACV is not clog.
Old Nov 4, 2003 | 11:03 PM
SC0TT's Avatar
Default Re: b16a idle problem (drift2live)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift2live &raquo;</TD></TR><TR><TD CLASS="quote">check for air pockets in your cooling system.</TD></TR></TABLE>
This caused a crappy idle on my b16
Old Nov 5, 2003 | 05:49 AM
Home Skillet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift2live &raquo;</TD></TR><TR><TD CLASS="quote">check to make sure your IACV is not clog.</TD></TR></TABLE>
This caused crappy idle on my B16A.
Old Nov 5, 2003 | 06:07 AM
fmfkid250's Avatar
Fast idle thermo valve This might be a iacv though
Old Nov 5, 2003 | 06:22 AM
SiZ's Avatar
SiZ
Mine does it too.. Apparently its a fast idle valve or something like that, but I have no luck locating one ever.
Yours could just as easily be a vaccum leak or something too, but mine's the weird idle valve.
Old Nov 5, 2003 | 06:40 AM
b16acrxer's Avatar
Default Re: b16a idle problem (SiZ)
where are the iacv and fast idle thermo valve and what do you do to fix them, i think my vacuum lines are fine... it didnt do this until i recently parked the car a few weeks ago and decided to let it run the other day.
Old Nov 9, 2003 | 03:00 PM
b16acrxer's Avatar
Old Nov 10, 2003 | 03:26 PM
VAAJ's Avatar
http://tech.hybridgarage.com/tech/index.html
look into the 88-91 civic/crx vtec (PDF)
more information then you will ever need
Old Nov 25, 2003 | 12:32 PM
EGbeater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift2live &raquo;</TD></TR><TR><TD CLASS="quote">http://tech.hybridgarage.com/tech/index.html
more information then you will ever need</TD></TR></TABLE>]
Page 6-47 of that PDF suggests that if the EACV doesn't read at 8-15 ohms, it is bad. Kind of a big range though . . .
Old Nov 25, 2003 | 12:34 PM
EGbeater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiZ &raquo;</TD></TR><TR><TD CLASS="quote">Mine does it too.. Apparently its a fast idle valve or something like that, but I have no luck locating one ever.
Yours could just as easily be a vaccum leak or something too, but mine's the weird idle valve.</TD></TR></TABLE>
Zee.I
Jul 11, 2021 11:36 PM
Pure Sol
16
Dec 31, 2007 12:06 PM
Freshsho
May 25, 2005 12:49 PM
RACEPAK
Nov 28, 2004 12:58 PM
LD_EGSICK
Jan 21, 2004 05:42 PM
