h22 custom gear sets...
Old Nov 4, 2003 | 07:43 PM
meanEG's Avatar
Default h22 custom gear sets...
i have a fully built all motor h22 swap in a eg. my gearing sucks. i once heard that the most desireable thing is to end the 1/4 in 4th gear at the peak power, is that true? if so than i am way off. would that be too low for the street. i datalogged my car tonight with my AEM EMS and i get up to 140 MPH in 4th.
i really want to keep a nice gear for the highway b/c 5th already sucks, 80 mph is about 4100 rpm. so what are my options with the gearing, should i just switch the final and transfer shaft? is this my only option? does anyone make a custom gear set for the h22 trans?
Old Nov 5, 2003 | 09:26 AM
GRTechnologies's Avatar
Default Re: h22 custom gear sets... (meanEG)
we can get you a gear set just let me know
Old Nov 5, 2003 | 04:39 PM
2156cc's Avatar
just set your car up for 9s in the 1/4 and you will be in the top of 4th.
Old Nov 5, 2003 | 05:51 PM
DaveF's Avatar
Default Re: h22 custom gear sets... (2156cc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2156cc &raquo;</TD></TR><TR><TD CLASS="quote">just set your car up for 9s in the 1/4 and you will be in the top of 4th. </TD></TR></TABLE>
not if he is running big slicks(26's or 28's) why do you think people desire close ratios trans? or try out differant final drives?
Old Nov 5, 2003 | 05:57 PM
speedworks's Avatar
Default Re: h22 custom gear sets... (2.2Lcivic)
what gear are you in when you go through the lights
Old Nov 5, 2003 | 06:10 PM
v4lu3s's Avatar
RTFM
who makes custom gears for the h22a? so far all i cna find is teh new final drive from ProDrive.
Old Nov 5, 2003 | 11:25 PM
DLB1994's Avatar
140mph in 4th you must not have a h22 tranny , you must have a f22 tranny and going right over 8000rpms to get 140 in 4th
Old Nov 6, 2003 | 05:46 AM
Default Re: h22 custom gear sets... (DLB1994)
try using the accord tranny with 28" slicks i've seen 140mph in 3rd gear in mr car
Old Nov 6, 2003 | 06:48 AM
DaveF's Avatar
Default Re: h22 custom gear sets... (GRTechnologies)
does ATS make anything for h22?
Old Nov 6, 2003 | 09:28 AM
CD8's Avatar
CD8
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">who makes custom gears for the h22a? so far all i cna find is teh new final drive from ProDrive.</TD></TR></TABLE> http://www.housemanautosport.com from canadia make custom FD.
Old Nov 6, 2003 | 11:30 AM
v4lu3s's Avatar
RTFM
so final drive is abotu all that can be altered right now. doesnt seem worth it to me honestly...
Old Nov 6, 2003 | 12:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">so final drive is abotu all that can be altered right now. doesnt seem worth it to me honestly...</TD></TR></TABLE>
the saenz ratio changes to make them closer together shifting @ 9500 you should only see a 2000 rpm drop between all the gears
Old Nov 6, 2003 | 12:51 PM
boostedh22a's Avatar
Default Re: (GRTechnologies)
what does that gear set run????$$$$$
Old Nov 6, 2003 | 02:36 PM
LNATURAL1's Avatar
I have a custom gear box for sale complete w final drive & Quafe LSD. $3,000 E mail if interested .. Jeremy@L-Natural.com
Old Nov 6, 2003 | 05:34 PM
H25's Avatar
H25
Default Re: (LNATURAL1)
the saenz setup has pretty good gearing especially from 1st to 2nd i talked to GR and they can get em.. i think its a good setup for a turbo car running 28s... I run the oem tranny and oem gears.. i wont say what kind or what particular gears but if you keep your car setup right from tire size to gear ratio down to the suspension.. you will see some good results..
Old Nov 6, 2003 | 05:36 PM
Default Re: (boostedh22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22a &raquo;</TD></TR><TR><TD CLASS="quote">what does that gear set run????$$$$$</TD></TR></TABLE>
a gear set is $1700 it comes with 1st tru 5th gear and input shaft
the dog box is around $5200 ant it comes with all gears an both shafts ready to drop in
2001GSRSC
Sep 26, 2017 12:28 PM
95exdsmkilla
May 22, 2008 07:13 AM
AznBlueBoy
May 29, 2007 03:45 PM
.BigSexy
Sep 26, 2005 05:16 AM
h22-cx-guy
May 23, 2004 02:22 PM
