91 HF b16 swap, is it multi point?
Old Nov 4, 2003 | 05:41 PM
Mentat Ghola's Avatar
Default 91 HF b16 swap, is it multi point?
My buddy has a 91 HF CRX. I looked under the hood and saw a resister box. Are the -1's multi point fuel injection?
Old Nov 4, 2003 | 06:30 PM
Benny Hinn's Avatar
Default Re: 91 HF b16 swap, is it multi point? (Mentat Ghola)
The HF is a multi port injected engine, just as the si.
Old Nov 5, 2003 | 02:58 AM
Grease Monkey's Avatar
Default Re: 91 HF b16 swap, is it multi point? (Benny Hinn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benny Hinn &raquo;</TD></TR><TR><TD CLASS="quote">The HF is a multi port injected engine, just as the si.</TD></TR></TABLE>
Old Nov 5, 2003 | 04:18 AM
VTECVillain's Avatar
Yes, the 88-91 CRX's are MPFI which makes swapping easier. If you plan to install a B16, you'll need to change the knuckles and hubs to 88-91 Civic/CRX DX or Si or 90-93 Integra's so the axles will fit. The CRX HF and the Civic STD have a different size (smaller) with a different amount of splines on the outer joint.
Old Nov 5, 2003 | 07:01 PM
Default Re: 91 HF b16 swap, is it multi point? (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, the 88-91 CRX's are MPFI which makes swapping easier. If you plan to install a B16, you'll need to change the knuckles and hubs to 88-91 Civic/CRX DX or Si or 90-93 Integra's so the axles will fit. The CRX HF and the Civic STD have a different size (smaller) with a different amount of splines on the outer joint.</TD></TR></TABLE>
Are u shittin me? i got change that whole thing?
Old Nov 5, 2003 | 07:16 PM
hybrider's Avatar
he's right.
Old Nov 7, 2003 | 03:23 PM
iwhichisme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mentat Ghola &raquo;</TD></TR><TR><TD CLASS="quote">
Are u shittin me? i got change that whole thing?</TD></TR></TABLE>
no doubt!!!, but is not like thats any harder than the actuall motor swap. It is neccessary.
Old Nov 8, 2003 | 12:25 AM
MIRRAdekhtc's Avatar
Default Re: 91 HF b16 swap, is it multi point? (iwhichisme)
except for the 88-91 dx's....they are dpfi...
kslimm0714
Jun 14, 2006 09:29 AM
SiR Inspired ED7
Feb 13, 2006 09:43 PM
onlyneed4
15
Jul 6, 2005 10:04 PM
pirocrxracer
Sep 10, 2003 05:18 PM
p0pe
Nov 22, 2002 02:54 PM
