BUILDING TURBO kit, please look.
Old Nov 4, 2003 | 05:02 PM
Frostedsol's Avatar
Default BUILDING TURBO kit, please look.
http://cgi.ebay.com/ebaymotors...33742
I have a 93 honda Del sol Si 1.6 SOHC VTEC
I want to add this to it to work
Good buys? Gonna fit yes/no? anything else that I would need?
thanks!
-Frost
(i did want a zex nitrous kit, but, turbos are just too....tempting. )
Old Nov 4, 2003 | 05:22 PM
Frostedsol's Avatar
Default Re: BUILDING TURBO kit, please look. (Frostedsol)
bump
Old Nov 4, 2003 | 05:25 PM
GsR HtCh's Avatar
looks like a used piece of crap. and the stock engine couldnt hold much boost anyway
Old Nov 4, 2003 | 05:28 PM
WangChung's Avatar
you will need:
-oil/water lines
-charge piping
-intercooler(off a 2g talon or similar)
-turbo adapter plate
-manifold(chopped up std)
-fuel management(fuel pressure reg/inline pump, etc)
thats all i can think of off the top of my head! i am in the process of doing the same thing to my d16y7! if u get a used turbo off a talon, the wastegate is set at 7-8 psi, perfect for stock internals.
Old Nov 4, 2003 | 05:31 PM
Bailhatch's Avatar
Default Re: BUILDING TURBO kit, please look. (97civhatch)
I'm putting that same turbo on the same engine in about a week. I don't know how it will respond. Seems like it will work fine but the compressor seems pretty small. and ya you'll all that other stuff or equivlant
Old Nov 4, 2003 | 06:07 PM
HXvtec's Avatar
Default Re: BUILDING TURBO kit, please look. (Bailhatch)
id buy it.
Old Nov 4, 2003 | 06:08 PM
Frostedsol's Avatar
so, dont buy the turbo up there?
I didnt buy the kit. just seemds....crappy. lol
Old Nov 4, 2003 | 06:13 PM
GsR HtCh's Avatar
are you plannin on doin internals
Old Nov 4, 2003 | 06:16 PM
Quad-Damag's Avatar
Default Re: BUILDING TURBO kit, please look. (98civichtchback)
that ebay kit is ghetto, im not a huge fan of the cx turbo manifolds, just buy a custom manifold so u can have a exturnal wasteagate and get like a T3 turbo, u will be happy with it on your D Series.
Old Nov 4, 2003 | 06:53 PM
shermanyang's Avatar
Default Re: BUILDING TURBO kit, please look. (Quad-Damge)
the kit is crap...don't buy it. the turbo however looks pretty decent.
Old Nov 4, 2003 | 07:04 PM
couter.net's Avatar
Default Re: BUILDING TURBO kit, please look. (shermanyang)
Goto to a junkyard before that :/
Old Nov 4, 2003 | 07:11 PM
Ferio Something's Avatar
Well he already said he didnt buy it. THe turbo looked good and to be honest, from experiencing a JY turbo, that stuff that was posted didnt look bad at all. No you couldn't really tell from a picture of the stuff worked but taking a chance, when that VAFC is well worth more than 200 ALONE..or at least 150.. you could have bought it. Oh well it's over now.
Im sure you've done research. Just keep doing it. I'm sad that I had to sell my setup for 625..and it was done. Just needed to be put in. sad sad.
Old Nov 4, 2003 | 08:10 PM
Frostedsol's Avatar
so that turbo up there will be a good deal? I have done a little research on turbos for my D16. I have heard that the used talon turbos are good (dont know what kind) and that the T3's are good and the T4's are too, but they are bigger.. which should I get? are they the same?
-Frost
Modified by Frostedsol at 11:41 PM 11/4/2003
Old Nov 4, 2003 | 08:29 PM
loco_ese's Avatar
IMO the best bet for us SOHC's would be a T3 .60 A/R .48trim with external wastegate (a tial 38mm would be best, but for cost wise a turbonetics will suffice) you can also get a log-style manifold and not need an adapter plate because most turbo hybrids are t3/t4. Also too, you likely will be able to keep your a/c with most of the log manifolds. --you'll then need all the other necessary parts to complete the turbo setup like charge pipes, intercooler, oil lines (coolant lines in some cases), ignition and fuel upgrades, wastegate, blow off valve, intake w/ filter, downpipe (can use 3" with lovefab.com sidewinder), exhaust, clutch, and then a rag to wipe the big *** smile off your face when you make your first "kill".
keep reading the H-T threads, knowledge makes power.
Old Nov 4, 2003 | 08:36 PM
Andres-eh2's Avatar
if you dont plan to build your motor go with the t25/t28 setup. safe and it'll spool quick.
if not, go with a t3/t4 kit. but you gotta be careful and you'll be better off buying a kit IMO.
DO IT RIGHT THE FIRST TIME
hondaEg_808
May 10, 2008 11:02 PM
SiBirdie
May 27, 2005 09:48 AM
tonysaccord
Jan 19, 2005 05:46 AM
accordfreak
Aug 27, 2004 02:01 AM
JDMnerd
Aug 26, 2004 10:36 AM
