Coolant loss, but don't know where
I have a 1991 Honda Accord and for some reason i have to keep on filling the reservoir. I changd the oil and found no coolant, no white resedue under the oil cap, and no drips or pudles of coolant under car. Where is all my coolant going?
I ate it
No, seriously, umm... the best idea that I have is that you may have a slow leak (a crack in the radiator, etc) that's leaking onto one of the many surfaces in the lower part of the car...and then flying out as you drive (hence you not noticing it). I had this happen once, where I had a VERY small crack at the top of my radiator, and coolant was seaping out of it (especially at higher temps where the pressure was getting higher), and literally just getting slung in who knows what place.
May want to go get a shop to test the coolant system out for you....
- Nathan
- Nathan
yeah man. look for a leak. is your rad. cap the original? check all your hoses. it may be very small, but if you can follow the coolant lines through the head and back to the return, and look around the thermostat housing.
good luck
good luck
ricerollz
Sep 22, 2010 10:05 AM
turbotime
Nov 1, 2005 05:36 AM
