ITR trunk brace
Old Nov 4, 2003 | 12:31 PM
gsr-2nr's Avatar
Default itr trunk brace
Can someone please post a pic of their trunk brace i want to c how it bolts up gonna put one in my car. want to how big and how far apart the bolts are and stuff thanks in advance.
(tried search already but none with pics that worked on my comp anyway)
Old Nov 4, 2003 | 12:34 PM
hungsteR's Avatar
Default Re: itr trunk brace (gsr-2nr)
http://www.geocities.com/bretq....html
Bret Q
Old Nov 4, 2003 | 12:40 PM
gsr-2nr's Avatar
Default Re: itr trunk brace (hungsteR)
i would like a pic of an oem itr one. i take it it doesnt fit a gsr. so what are those 2 threaded holes for in the hatch?
Old Nov 4, 2003 | 12:58 PM
DsITR's Avatar
here are some pics of the oem goodness. Hope the pics are clear, if there is something specific you need lemme know. I removed the center plastic piece for clarity..you couldn't see ish w/the black behind the bar..
passenger side
drivers side
HTH
Modified by DsR at 3:11 PM 11/4/2003
Old Nov 4, 2003 | 01:00 PM
frogsr's Avatar
Default Re: itr trunk brace (DsR)
nice pics.
gsr-2nr, those threaded things are for the child safety seat tie downs, i think...
Old Nov 4, 2003 | 01:07 PM
Erik B's Avatar
I know a guy with a LS that tried to put one in and cracked it off. It ripped right off and cracked the inside part wear he bolted it up too. I guess the car is not as stiff or something but I would do a little more reseach and see if it has happend to anyone else before you try it.
Old Nov 4, 2003 | 01:12 PM
Fac3Man's Avatar
Default Re: (Erik B)
My brother has it on his GS-R fits fine no probs, dont know how he mounted it though.
Old Nov 4, 2003 | 01:36 PM
gsr-2nr's Avatar
Default Re: (Fac3Man)
thanks a bunch dsr xactly what i needed BTW what size are the bolts on it
Old Nov 4, 2003 | 03:24 PM
esponet's Avatar
you could buy that body piece from acura and remove yours and weld the itr one soit will have the thread for the bar.
Old Nov 4, 2003 | 03:31 PM
gsr-2nr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fac3Man &raquo;</TD></TR><TR><TD CLASS="quote">My brother has it on his GS-R fits fine no probs, dont know how he mounted it though.</TD></TR></TABLE>
it will fit in gsr's but you have to drill the hols for it
Old Nov 4, 2003 | 05:45 PM
b18cu's Avatar
Default Re: (gsr-2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr-2nr &raquo;</TD></TR><TR><TD CLASS="quote">
it will fit in gsr's but you have to drill the hols for it</TD></TR></TABLE>
i dont think you have to drill holes... there are some there just not threaded. ( i tried putting my friends in my car but ran into that problem.)
Old Nov 4, 2003 | 06:48 PM
DsITR's Avatar
Default Re: (b18cu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cu &raquo;</TD></TR><TR><TD CLASS="quote">
i dont think you have to drill holes... there are some there just not threaded. ( i tried putting my friends in my car but ran into that problem.)</TD></TR></TABLE>
In that case just pick up a tap and die set and you are all set.
Ill get the dimensions off the bolts for you later this evening...my damn calipers are gone
Old Nov 4, 2003 | 07:12 PM
threatcon13's Avatar
New User
Do a search bro. Theres a thread in the integra forum w/ instructions and pictures. It even tells you what size bolts you need, what washers and nuts to use. i am going to use that thread when i put a itr trunk brace in my car.
Old Nov 5, 2003 | 08:21 AM
arkabee's Avatar
Default Re: (b18cu)
not on a 1997 gs-r. (why specifically a 1997? because that's what i have, and that's what i drilled holes into.)
you have to drill holes. (why drill holes? because the holes for the brace did not exist. were there holes? yes. were they for the brace? no.)
can you bolt it to the child safety restraint holes? sure, if you want it to rip out and rip the restraint mount points off.
check the bretq page mentioned waaaay at the top of this thread. it has pictures and everthing.
Old Nov 5, 2003 | 11:10 AM
rtype11's Avatar
Default Re: (arkabee)
well i went through all this only tolearn that the the ITR brace only fits stock on the itr, i dont want to be drilling to get this in, so its for sale if anyone needs it, bit scratched up cause i use it for a breaker bar every so often.
Beasty18C5
Apr 3, 2009 07:50 PM
zc911
Jan 8, 2006 11:32 PM
threatcon13
Jan 3, 2006 10:21 AM
hi mom
Feb 10, 2005 09:53 PM
EndlessGarageEG6
Nov 9, 2002 07:46 AM
