JRSCed b18C1 and ITR LSD tranny all fit into a 89 CRX HF?
Old Nov 4, 2003 | 11:31 AM
92TEGsrSC's Avatar
Default JRSCed b18C1 and ITR LSD tranny all fit into a 89 CRX HF?
I'm considering buying a 89 CRX HF as a beater with the eventual plan of swapping what I've got in my 94 GSR into the CRX. Could I swap the GSR engine w/ the JRSC and ITR tranny into the CRX?
Will I be able to use my ACT stage II racing clutch? What about the GSR axles???
knowing that I will have both of these cars, with everything in them, what will I need to do the swap-- if it is even possible?
Thanks in Advance,
Zack
Old Nov 4, 2003 | 04:48 PM
92TEGsrSC's Avatar
Default Re: JRSCed b18C1 and ITR LSD tranny all fit into a 89 CRX HF? (92TEGsrSC)
ttt
Old Nov 5, 2003 | 04:15 AM
dash's Avatar
yes the b18c w/ the jrsc will fit, mine fit niece however if your going to install it all at once, take off the brake mastercylander and don't forget to dent the frame rial were the alt. will sit. good luck
Old Nov 5, 2003 | 04:23 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TEGsrSC &raquo;</TD></TR><TR><TD CLASS="quote">Could I swap the GSR engine w/ the JRSC and ITR tranny into the CRX?</TD></TR></TABLE>
It would depend on the mount kit used as to whether or not the JRSC would fit without any issues. I know with HASport mounts the JRSC will fit since it places the motor closer to the front. Since you plan to use an ITR tranny which is hydro, I would get the new HASport EF hydro mount kit and that will take care of getting it all bolted in properly.
Old Nov 5, 2003 | 05:41 AM
92TEGsrSC's Avatar
thanks a lot guys...
Old Nov 5, 2003 | 08:26 AM
92TEGsrSC's Avatar
will I be able to use the axles? someone told me that a GSR is wider than a CRX so I'd need different axles?
Old Nov 5, 2003 | 10:08 AM
showtymers619's Avatar
* B A N N E D *
Default Re: (92TEGsrSC)
need the dx or SI hubs
Old Nov 5, 2003 | 04:31 PM
R6Boy69's Avatar
Default Re: (ShowTymers619)
with 90-93 integra axles
Old Nov 5, 2003 | 04:48 PM
XJamesX's Avatar
Default Re: JRSCed b18C1 and ITR LSD tranny all fit into a 89 CRX HF? (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
I know with HASport mounts the JRSC will fit since it places the motor closer to the front. </TD></TR></TABLE>
Actually the placeracing mounts place the motor further forward then the hasport mounts. The JRSC does fit with the hasport mounts, but it is an easier fit and less modification with the placeracing mounts.
-James-
Old Nov 5, 2003 | 07:02 PM
Default Re: JRSCed b18C1 and ITR LSD tranny all fit into a 89 CRX HF? (B18C5crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5crx &raquo;</TD></TR><TR><TD CLASS="quote">The JRSC does fit with the hasport mounts, but it is an easier fit and less modification with the placeracing mounts.</TD></TR></TABLE>
Funny thing that I own a 91 CRX DX with 96 B18B1/92 YS1 GSR tranny using HASport billet EF mounts and I used to have a JRSC on it. It was a tight fit but nevertheless it was there for a while.
Old Nov 5, 2003 | 08:19 PM
92TEGsrSC's Avatar
thanks for all the input, guys. How much do you guys figure this swap would cost me to do on my own, knowing what I already have. And how much do you think it would cost to have someone do the swap for me. Thanks again
Old Nov 9, 2003 | 05:43 PM
Wes V's Avatar
I don't question that VTECVillain had a JRSC in his EF, but I also believe that the Place Racing mounts do put the engine more forward than the Hasport.
Wes
Old Nov 10, 2003 | 09:19 AM
dash's Avatar
Default Re: (Wes V)
ether way my jrsc fit with place raceing mounts and my radius arms dont hit the crank pulley.
Old Nov 10, 2003 | 04:01 PM
92TEGsrSC's Avatar
Default Re: (dash)
very good to hear
busychild
27
Sep 2, 2016 02:28 PM
memicah
15
Mar 10, 2006 10:03 PM
JohnnieChimpo
Jun 17, 2004 09:18 PM
djric23
Mar 21, 2004 09:58 AM
