Compression Test, are they about right?
91' CRX Si D16a6 SOHC nonvtec
145, 140, 145, 150
decent numbers? or not... I also have a stage3 cam w/ 270 duration and im not sure if taht would effect the numbers.
145, 140, 145, 150
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">numbers are low- should be at or around 180. </TD></TR></TABLE>
Couldn't my cam be the cause of the lower compression #'s?
Stock cams cause valves open and close quicker, so during the stroke the cylinder has more time to compress while the valves are closed
This is a Stage3 w/ 270 duration race camshaft, Would it be why?
Aftermarker cam w/ longer duration keeps the valves open longer so while during the stroke the valves are still open releasing air, thus giving a lower compression number because less air was compacted.
This is an untuned cam w/ stock camgear.
Just did a compression test on my car:
1 - 155
2 - 175
3 - 175
4 - 170
I'm a little worried about the #1 cylinder being so low, even though it's within 10% of the others. Should I be worried? I'm doing a leak down test tomorrow.
Oh, the car was fully warm, cranked until needle stopped moving, but I didn't pull the fuel fuse. 92,700 miles on car, mostly stock.
1 - 155
2 - 175
3 - 175
4 - 170
JDMs1eeper
Nov 5, 2003 09:55 AM
