Compression Test, are they about right?
91' CRX Si D16a6 SOHC nonvtec
145, 140, 145, 150
decent numbers? or not... I also have a stage3 cam w/ 270 duration and im not sure if taht would effect the numbers.
145, 140, 145, 150
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondudEf »</TD></TR><TR><TD CLASS="quote">A little worn...</TD></TR></TABLE>
what do you mean by that?
Couldn't my cam be the cause of the lower compression #'s?
Stock cams cause valves open and close quicker, so during the stroke the cylinder has more time to compress while the valves are closed
This is a Stage3 w/ 270 duration race camshaft, Would it be why?
Aftermarker cam w/ longer duration keeps the valves open longer so while during the stroke the valves are still open releasing air, thus giving a lower compression number because less air was compacted.
This is an untuned cam w/ stock camgear.
thats not bad or good. normal i would say if you have 150+k on the motor
i did mine like 2 months ago and got 175-178-176-175
this was done on a cold/warm motor.
the main thing to be worried about if the numbers are not consistant withing 10psi of each other.
JDMs1eeper
Nov 10, 2003 01:06 PM
