poor idle and running rich
Old Nov 4, 2003 | 11:23 AM
scratchy's Avatar
Default poor idle and running rich
93 accord running rich and don't know why think its because of throttle position sensor or map sensor and it has a shitty idle maybe because of sensor but any help would be much appreciated thankx
Old Nov 4, 2003 | 07:15 PM
88LXiProject's Avatar
Default Re: poor idle and running rich (scratchy)
can you give any more info? i mean, what's the behavior of the rpm's? when's the last time you had a tune up (plugs, wires, rotor, cap, air filter, etc.)? you may have a bad o2 sensor. i would try resetting the ecu first though.
good luck
Old Nov 4, 2003 | 08:30 PM
Excelerate's Avatar
you throwin a CEL?
Old Nov 10, 2003 | 09:29 AM
scratchy's Avatar
Default Re: poor idle and running rich (6GAccord2.3t)
what ????????????
Old Nov 11, 2003 | 06:37 PM
feelsfast's Avatar
is your check engine light on. cel = check engine light
Old Nov 11, 2003 | 06:54 PM
NathanMorris's Avatar
Default Re: poor idle and running rich (feelsfast)
it could be a number of things, you need to be more specific. It could be anything from a failing O2 sensor to a busted Intake Air Control Valve, to a half dozen other sensors....in reality, just about anything ... from what you have told us
- Nathan
livedew12
Jan 10, 2012 08:58 PM
colnago
Apr 7, 2007 11:14 PM
lopez
Oct 25, 2005 04:59 AM
95civiccoupe31
Jul 2, 2002 03:39 PM
clean
Oct 8, 2001 04:20 PM
