Here's my Set-up, guess my HP...
Old Nov 4, 2003 | 11:01 AM
Ryan C's Avatar
Default Here's my Set-up, guess my HP...
1994 GSR
ITR Valve Springs
Stock Valves
GSR Cams (stock timing)
New valve and Cam Seals
OEM Head Gasket
AEBS Head Studs
JDM ITR Pistons (81mm)
New Rings
Shot Peened GSR rods
ARP rod bolts
Fresh Bearings
Accordingly Done 2.5" exhaust w/ test pipe
Short ram intake
Stock OBD-1 P72 ecu
How Much WHP am i looking at?
Old Nov 4, 2003 | 11:27 AM
RS_H22's Avatar
Default Re: Here's my Set-up, guess my HP... (Ryan C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">1994 GSR
ITR Valve Springs
Stock Valves
OEM Head Gasket
AEBS Head Studs
New Rings
ARP rod bolts
Fresh Bearings
Short ram intake
Stock OBD-1 P72 ecu
How Much WHP am i looking at?</TD></TR></TABLE>
Heres a suggestion...
Theres a 82mm version of the ITR piston that will bump displacement up to 1842cc's and compression up to 11.5:1... Im pretty sure the cost is the same if not cheaper seeing they are an OEM replacement aftermarket cast piston...
AN-R sells them...
http://www.an-r.com/internals/pistons.html
Old Nov 4, 2003 | 12:21 PM
Ryan C's Avatar
Default Re: Here's my Set-up, guess my HP... (RS_H22)
the cost of the pistons are the same but i have to pay someone to bore my block
Old Nov 4, 2003 | 07:38 PM
NSX Bob's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS_H22 &raquo;</TD></TR><TR><TD CLASS="quote">
There absolutely are not 82mm OEM ITR pisons. Oversized OEM pistons for the ITR are 81.25mm.
Old Nov 4, 2003 | 07:44 PM
RS_H22's Avatar
Default Re: Here's my Set-up, guess my HP... (Type R Bob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R Bob &raquo;</TD></TR><TR><TD CLASS="quote">There absolutely are not 82mm OEM ITR pisons. Oversized OEM pistons for the ITR are 81.25mm.</TD></TR></TABLE>
read a lil further... here, Ill help ya out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS_H22 &raquo;</TD></TR><TR><TD CLASS="quote">Theres a 82mm version of the ITR piston that will bump displacement up to 1842cc's and compression up to 11.5:1... Im pretty sure the cost is the same if not cheaper seeing they are an OEM replacement <U>aftermarket</U> cast piston... </TD></TR></TABLE>
Old Nov 4, 2003 | 09:04 PM
tegasaurus's Avatar
lol, someone just got owned by illiteracy!
Old Nov 4, 2003 | 09:08 PM
RS_H22's Avatar
Default Re: Here's my Set-up, guess my HP... (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">lol, someone just got owned by illiteracy!
nah, its cool... I do the same thing all the time... I just skim through posts from time to time and sometimes I miss a thing or 2... it happens
Old Nov 4, 2003 | 09:14 PM
BolivianDc2's Avatar
are these pistons are reliable as OEM? i had somebody who wanted to sell me .5 over p30 copies, but didnt because I didn't know jack about them
Old Nov 5, 2003 | 05:46 PM
NSX Bob's Avatar
New User
nah, its cool... I do the same thing all the time... I just skim through posts from time to time and sometimes I miss a thing or 2... it happens</TD></TR></TABLE>
lol, fair enough. I skimmed it and got busted.
Old Nov 5, 2003 | 05:51 PM
smnowell's Avatar
So...do you actually know your whp and just want us to guess, or are we guessing so that we can give you a rough estimate?
Old Nov 5, 2003 | 06:03 PM
Ryan C's Avatar
Default Re: Here's my Set-up, guess my HP... (b16a ferio)
i dont have any numbers right now, i'll postem when i get em..
i just wanted to make sure i was on the right on the same page as you guys.
Old Nov 5, 2003 | 06:07 PM
smnowell's Avatar
you could have just searched around here. I believe there have been quite a few posts with peoples B18C motors with similar setups like yours and they have dyno charts and stuff, you could just gauge your motors performance from the performance of theirs. I know it won't be completely accurate, but it will be a better estimation than making a poll and asking what we think...
Old Nov 5, 2003 | 10:49 PM
Downey's Avatar
so u have a B18C1 with JDM ITR pistons, Intake, test pipe and exhaust? 150-160hp..
Old Nov 9, 2003 | 12:32 PM
myhatchrips's Avatar
Default Re: Here's my Set-up, guess my HP... (Downey)
yea hes right. so basically an 82mm piston is .040 inch oversize/
Old Nov 9, 2003 | 12:37 PM
advanracing62's Avatar
Default Re: Here's my Set-up, guess my HP... (myhatchrips)
where's the option for -10whp for bench testing?
SiR-G DC
430
Aug 28, 2013 05:59 AM
madking411
Jan 9, 2010 11:50 AM
JdmTypeRdc2
Aug 17, 2009 06:41 AM
B18C1NMotion
11
Jul 13, 2008 01:33 AM
Drew17th
Jan 18, 2007 08:45 PM
