Will N1 catback work when lowered with tie bar in summer then raised in winter?
Old Nov 4, 2003 | 09:19 AM
92BlackSi's Avatar
Default Will N1 catback work when lowered with tie bar in summer then raised in winter?
Since I have lowered the car and strapped on an aftermarket muffler, the piping from the axleback is banging against the LCA making the car all but a pleasure to drive. I am really liking the things I have heard about the N1 and the it's fitment being angled.
In the future I plan on getting a tie-bar etc.. for the car I also need to, in the winters, raise the car for the snow.
Will the N1 give me no probs lowered with a tie bar? AND no problems raised up with the tie bar?
TIA
Old Nov 4, 2003 | 09:25 AM
Spade's Avatar
Default Re: Will N1 catback work when lowered with tie bar in summer then raised in winter? (92BlackSi)
Don't angled exhausts route where the lower tie bar would go between the subframe?
Old Nov 4, 2003 | 09:40 AM
92BlackSi's Avatar
I think I could get it custom bent to hang below that but it may be too low. I just hate this banging noise, need something that works.
Anybody tried a side exhaust (small tip) by the rear quarter?
Old Nov 4, 2003 | 09:44 AM
Spade's Avatar
Default Re: (92BlackSi)
have you tried bending your exhaust hangers to better position the exhaust?
Daniel's Avatar
Default Re: Will N1 catback work when lowered with tie bar in summer then raised in winter? (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">Don't angled exhausts route where the lower tie bar would go between the subframe?</TD></TR></TABLE>
Only the ones like the Buddy Club. (Spec I? Can't remember which.) Other angled N1s such as the A'PEXi N1 and 5Zigen Fireball use the OEM path but then just have the muffler jut out at an angle under the bumper.
Old Nov 4, 2003 | 09:48 AM
92BlackSi's Avatar
Default Re: Will N1 catback work when lowered with tie bar in summer then raised in winter? (Daniel)
Isn't the OEM path over the LCA? I have not seen an N1 over the LCA all have went under or to the side of the LCA if custom??
I have not tried bending exhaust hangers I did try new runnber mounts though = no good. The problem is that when I try to make the part by the LCA higher to avoid contact it ends up making the muffler section higher. The muffler is damn near resting on the rear bumper as it is.
Old Nov 4, 2003 | 10:05 AM
King Tut33's Avatar
I have a tie bar and an APEX'i N1, and the tie bar doesn't affect clearance when raised or lowered. The N1 does not follow the OEM path. Instead of going over the LCA, it goes under and then has to angle up to hit the stock exhaust hangers for the muffler. Here is a pic of the clearance on mine:
Old Nov 4, 2003 | 10:08 AM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92BlackSi &raquo;</TD></TR><TR><TD CLASS="quote">Isn't the OEM path over the LCA? I have not seen an N1 over the LCA all have went under or to the side of the LCA if custom??
My bad. I didn't realize you had a hatch. Yeah, then the OEM path is over the LCA. For coupes/sedans, though, the A'PEXi N1 goes over the LCA just like the stock exhaust piping.
Old Nov 4, 2003 | 10:15 AM
92BlackSi's Avatar
Default Re: Will N1 catback work when lowered with tie bar in summer then raised in winter? (King Tut33)
Do you ever get any banging from the exhaust on some suspension part underneath? What about clearing the ground? You scrap often?
JSPECSIR
Jun 6, 2005 01:22 PM
92civeg
Aug 6, 2003 04:10 PM
MaxBoost
13
May 15, 2003 12:43 PM
Duck Sauce
Feb 15, 2002 01:59 AM
