Would you trade 15" rotas for a Front and Rear SI brakes?
Curious what everyone thinks about this.
Personally, it would depend if I really wanted the brakes or if I really wanted the rims. :-)
Got the brakes, really want the rims.
EDIT: Yes a set of 4.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos »</TD></TR><TR><TD CLASS="quote">4 wheels with tires?</TD></TR></TABLE>
I dunno, man: the Si rear discs really do make a noticable difference. The fronts aren't anything incredible, but I dunno if I'd want to go through all the work of ripping out my brakes just to put some Rotas on my car.
I'd say keep the brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">I dunno, man: the Si rear discs really do make a noticable difference. The fronts aren't anything incredible, but I dunno if I'd want to go through all the work of ripping out my brakes just to put some Rotas on my car.
I'd say keep the brakes.</TD></TR></TABLE>
Brakes are in the garage.
EDIT: Forgot to meantion
<---- on borrowed steelies.
Which wheels??
I mean, on a EX, you only need the rear conversion. You can buy rear disk setups from a Civic Si for $200. Depends if the wheels are worth more than $200, get the wheels!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">Which wheels??
I mean, on a EX, you only need the rear conversion. You can buy rear disk setups from a Civic Si for $200. Depends if the wheels are worth more than $200, get the wheels!</TD></TR></TABLE>
Any ROTAs.
Yes the EX only needs the rear however, a DX owner might want the whole thing
Any ROTAs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">so si front brakes are the same as ex? referring to eks... true?</TD></TR></TABLE>
Almost. Calipers are slightly different but Disk size is the same.
Goes for 92-95 EX/SIs as well.
99-00 si front brakes are exactly the same as 96-00 ex. Check the part #s. Upgrade calipers off 94-01 Teg onto ex or si rotors. They bolt right up.
huh. you learn something new every day.
btw, i would trade the brakes for a set of rotas. unless they are in near mint condition and/or the wheels are beat up. your on borrowed steelies. **** brakes they make you slow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">
Goes for 92-95 EX/SIs as well.</TD></TR></TABLE>
Minor correction 92-95SI has the little front brakes.
If you want the rotas then go for it, even if you sold the brakes on ebay, you would only get about what it would cost for a new set of rotas. Do your brakes include MC and booster? or just front/rear brakes? If it includes mc and booster, I would want a little cash to go along with the rotas.
