Sound like a motor mount problem?
Old Nov 4, 2003 | 07:57 AM
Mr.Saturn's Avatar
Default Sound like a motor mount problem?
Ever since I bought my 90 CRX (2 yrs ago) I have noticed that when you accelerate from a stop quickly or snap the throttle shut the car rocks forward and back, and in turn bouncing the revs around a little as it slows or speeds up. Its not horrible but is probably worse than it should be. Recently it occured to me that it may be the motor mounts; does that sound like it to anyone else? If I do replace them I will get some polyurathane inserts also. I'll have to climb under my car later this week to be sure but just wanted to check with everyone here.
Old Nov 4, 2003 | 09:38 PM
Mr.Saturn's Avatar
Default Re: Sound like a motor mount problem? (Mr.Saturn)
up
Old Nov 4, 2003 | 10:17 PM
Malgerus's Avatar
Check the front mount that attaches to the front crossmember... I had a bolt fall outta there once and the whole motor moved back and forth. Also, get some Polyurethane Goo and do your mounts up. Do a search for Keithv's post.
Old Nov 5, 2003 | 06:54 AM
Mr.Saturn's Avatar
Default Re: Sound like a motor mount problem? (Mr. S)
Energy suspension inserts are like 12 bucks for a set, had I known that I would have gotten them long ago.
Old Nov 6, 2003 | 05:36 PM
Mr.Saturn's Avatar
up, anyone else with similar experience?
Old Nov 7, 2003 | 10:42 AM
Mr.Saturn's Avatar
Old Nov 7, 2003 | 10:55 AM
spaceman's Avatar
it sounds like the front tie rod bushings to me..try to get the es master bushing set for your crx if you can or just try replacing some important bushings..motor mount bushings will stiffen some things up,but it also adds some vibration..good luck
Old Nov 7, 2003 | 08:46 PM
Mr.Saturn's Avatar
Default Re: Sound like a motor mount problem? (spaceman)
in car vibration is fine, exhaust does that nicely already, its the car jerking forward and back when i snap the throttle closed or oped too quickly i hate, I've learned not to do it but i think i may be avoiding a problem ive had since i bought the car
Old Nov 8, 2003 | 04:28 AM
NCchris's Avatar
Check your throttle cable, could be too tight. It needs a little slack.
chris
i_VTEC
Oct 3, 2007 05:07 PM
StolenTeg
Apr 20, 2005 04:53 PM
C-Murdock
Dec 19, 2002 02:36 PM
90Hatch
Nov 12, 2002 05:22 AM
stealthteg
May 21, 2002 02:33 PM
