b18c1 swap into eg
hey there guys, im from down under australia,
im running into some problems with my swap. i just bought a b18c1 halfcut but i got a d15b carby motor. what im concerned about is the wiring. do i wire the additional wires (vtec solenoid, vtec oil pres, knock) onto my ecu harness? and how? any help will be much appreciated... cheers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiksiracer1 »</TD></TR><TR><TD CLASS="quote">go clcik the search button, and search for wiring vtec, there is prolly bout 20 topics in detail about this, good luck. </TD></TR></TABLE>
yeah mate..sorrie cant help mate..
instead of being a dick ill let you in on a couple sites.
http://tech.hybridgarage.com/tech/adrian-5g.html
http://www.c-speedracing.com/h...p.php
if you need more pm me.
have a good one mate
il just tell you what to do and not be an ***
on your ECU, move the A20 wire, just unclip it, and strip it and put it in the a17 plug, which is empty, that will give you the secondary butterflies, the next thing to do is look at the wiring harness on the passanger shock tower, look for a Pink wire from the engine to the harness , but it doesnt go from the harness to the ECU, so yea the wire is PINK with a BLUE stripe, make a new wire from the other side of that and run it into your D3
PeaCE
PeaCE
northkai3
Jun 26, 2005 01:35 PM
, props for giving him a hand.
