effect of brake pad material?
Old Sep 7, 2001 | 07:27 AM
serious's Avatar
Default effect of brake pad material?
what effect does brake pad material have? i'm thinking of using organic pads in the rear instead of semi-met for cost reasons. is there going to be a difference in braking, or are they just going to wear down faster?
Old Sep 7, 2001 | 07:10 PM
4wsB21a's Avatar
New User
Default Re: effect of brake pad material? (serious)
if you switch to organic pads, you need to be careful of a couple of things. the organics will stop the car a little faster, but nothing to get too excited about, and yes, they will wear down faster. however, if you do a lot of hard stopping and fast driving, you will need to be careful not to catch the pads on fire. organics have a much less heat tolerance than the semi-mets do. if you do a lot of racing type driving, do not go with the organics, unless you try putting on cross-drilled rotors. even that may not be enough to keep the pads from overheating and burning.
TailZ
Honda Civic (2001 - 2005)
Oct 13, 2008 01:57 PM
B serious
Honda S2000
23
May 1, 2007 05:23 PM
verycleanhatch
Jan 9, 2007 04:15 PM
Arsenal
Nov 30, 2006 12:50 PM
Gen5lude
Apr 1, 2003 01:04 PM
