Completed my minime swap.
Old Nov 3, 2003 | 11:34 PM
Evil EG's Avatar
Default Completed my minime swap.
Well started this morning at 7am and finished at 2am today, with many breaks in between. I pulled the beat up old d16a6 out of the CRX and dropped in a 98 d16y7 block (that I picked up for free) and a 93 d16z6 head (got for $50). Well I was fairly easy. I had bought the z6 head bolts but they ended up not working and I ended up using the y7 head bolts. I used the a6 alternator and intake manifold so I could remain obd0 and since the y7 block dosent have a ECT sensor on the block I connected the two wires that went to the sensor together for a temp fix so the fans always on for now. I used the a6 dizzy with some modification I made it fit. Switched the driver side mount bracket to the a6 mount bracket. Used the stock a6 manifold. And stock Si Ecu. And used a RPM switch for the Vtec. Im really please with the results as this is my beater/my sisters car. So for $50 and some change for gaskets its a fun car.
Modified by Evil EG at 3:08 AM 5/28/2004
Old Nov 3, 2003 | 11:35 PM
Evil EG's Avatar
Default Re: Completed my minime swap. (BVM)
Oh yeah it has a nice new paint job also. We had left over paint so we color matched the valve cover to.
Old Nov 3, 2003 | 11:48 PM
Origin's Avatar
very nice job.
Old Nov 4, 2003 | 03:22 AM
ImportsCRX's Avatar
nice job indeed
Old Nov 4, 2003 | 04:25 AM
WhatThaFrig's Avatar
Default Re: (ImportsCRX)
Good job. Looks good.
Old Nov 4, 2003 | 04:37 AM
USDM 4G VTEC's Avatar
congrats on the new engine
looks good
clean head indeed
as for the fan thermoswitch u could have taken the plug fof behing the block and take the sensor off the A6 and put it on the block
be careful bc u can break the pins on the thermosiwthc easy and they are 40 at honda
Old Nov 4, 2003 | 04:54 AM
Evil EG's Avatar
Default Re: Completed my minime swap. (USDM 4G VTEC)
Yeah we tried to to swap the sensor over to the other block but there wasnt a hole big enough for it anywhere on the block there was a big drain bolt that we were gunna drill out the center of and thread it in. We are gunna try it today, I just need to go out and see if I can find a tap big enough.
Old Nov 4, 2003 | 05:22 AM
no dont do that u are going to regret it
the bolt should be next to the oil press witch and the oil filter..... if not u can just cut the wires of the thermo on ur car and rewire it to the thermo switch o the thermostat housing on the Y7 bloock
Old Nov 4, 2003 | 05:54 AM
Evil EG's Avatar
Ok cool thanks I think Ill see if I can rewire it to there.
Old Nov 4, 2003 | 06:04 AM
OnePointFive's Avatar
overrated.
looks awesome brandon, now your sister will get all the hoes in that CRX....oh wait.....
nevermind
Old Nov 4, 2003 | 06:24 AM
Evil EG's Avatar
Default Re: Completed my minime swap. (OnePointFive)
LOL ricky, you go to hell you goto hell and you DIE.
Old Nov 4, 2003 | 07:59 AM
T3T495GSR's Avatar
wow brandon , that looks amazing and fresh and so clean YO
Old Nov 4, 2003 | 08:09 AM
manson's Avatar
Default Re: Completed my minime swap. (T3T495GSR)
sweet... great work
Old Nov 4, 2003 | 09:13 AM
91civicDXdude's Avatar
the fan switch will be located on the thermostat housing. also, you should've used the z6 intake manifold. the runners and ports are a little bit larger. you can use it with the pm6
turbogrs
Sep 13, 2010 02:02 AM
pooorman's type-r
11
Mar 20, 2009 11:36 AM
Tw1n Turb0 Z
33
Oct 8, 2006 10:19 PM
dynamicauto
May 24, 2004 07:39 PM
