sweakin noise from front wheels
Old Nov 3, 2003 | 07:15 PM
SIMATIC's Avatar
Default sweakin noise from front wheels
i began to notice a little sqeeling noise from the front wheels at times. its usualy when im rolling @ 20-30 mph i notice it. it happens then goes away from days then come sback.. my friend told me to chck my boots, but i think there good. when i changed my oil last week, i didnt notice a rip in any sooo......anyone else got suggestions? ***** joints??bearings??anything?? even happens when i brake too.thanks for the help
98 honda accord EX
129k 5 spd
Old Nov 3, 2003 | 07:40 PM
iam7head's Avatar
Default Re: sweakin noise from front wheels (SIMATIC)
check uppper ball joint, and the cv boot and axle, they are mostly the problem
Old Nov 3, 2003 | 07:59 PM
jspark79's Avatar
think about checking your calipers?
Old Nov 3, 2003 | 09:19 PM
Nick H's Avatar
New User
Default Re: sweakin noise from front wheels (jspark79)
what kind of pads do you use...and make sure your dust shield isn't making contact with the rotors...are the rotors scored anywhere?
Old Nov 4, 2003 | 03:34 PM
SIMATIC's Avatar
Default Re: sweakin noise from front wheels (Nick H)
as far as i know, the car was used, my rotors were cut recently by previuos owner, but i found a receipt and it says that that was the last time they can be cut.... i installed raybestos brake pads in august so there new .why should i check the calipers?? but i will check the upperball joints,cv joints and dust sheild this weekend. thanks for the advice
well i forgot to mention, i live in a neighborhood full of potholes and bumpy streets. o0000 yea and those ugly loooking bumper guards that do absolutely nothing to save your bumper!
__________________________________________________ __________________
"in the end, only one will stand up above the rest" -:
Old Nov 4, 2003 | 04:42 PM
fluxion's Avatar
amin n'rangwa edanea
wheel bearings, maybe?
Old Nov 4, 2003 | 05:46 PM
jspark79's Avatar
if i am correct the calipers hold your pads. if your calipers are offset then your pads are offset and therefore rubbing when they should not. its create an uneven wearing, which is where the squeeling comes from.
hope this helps
Old Nov 4, 2003 | 07:24 PM
SIMATIC's Avatar
what u mean offset... pistions not engaging evenly? or i didnt tighten somehting when i replaced the pads?
Old Nov 4, 2003 | 07:27 PM
lessthanpunk05's Avatar
dude it's them damn breaks ur rollin with i had the same proplem and changed the rotor's and pads and it was all good it's not the ball joint b/c i've busted one of those ******* too when u bust one of those it will shake same for cv joints
i give my car hell hehe
Old Nov 5, 2003 | 04:33 PM
jspark79's Avatar
by saying offset i mean your pads are not aligned with the rotors. the other guy was right about cv/ball joints. you would feel it if it were. if your car drives pulls to one side, chances are that i am right. if i doesn't pull to a side then perhaps i am wrong
Old Nov 5, 2003 | 04:58 PM
97F22B2's Avatar
my car makes a noise when i go over things or brake really fast, i think its my upper A arms slidding up the fender wells, damn Pro kit
Old Nov 5, 2003 | 05:38 PM
SIMATIC's Avatar
Default Re: (97F22B2)
no it dont really pull to one side, except when i drive on those uneven/wavey streets...well looks like i got my answer, ill check it out, thanks alot for the help
mouab18c1
Mar 2, 2009 04:19 PM
methos713
Suspension & Brakes
11
Oct 3, 2008 01:33 PM
omarisramo
Dec 7, 2007 01:20 PM
doh boy
13
Dec 3, 2003 04:17 PM
davidnyc
Jun 13, 2002 03:19 PM
