HID in a stock EK housing...
Old Nov 3, 2003 | 06:38 PM
Petah's Avatar
Default HID in a stock EK housing...
OK...i have done a fair bit of research here on HT. It seems like there is 2 ways
of mounting a D2S/D2R HID into the stock EK housing.
1. Retrofitting a HID projector into a stock EK housing.
2. Buying a H4 shield/adapter making the HID bulb plug and play.
However, in order to get the true output of HIDs, option 1 is the only way to go. But my question is, how is the light output for option 2? I know alot of people has done this but i don't see many pictures of the light output, cutoff, spead etc. Anyone has done this and got some pics or comments to share?
Old Nov 4, 2003 | 07:30 AM
96civicB20's Avatar
Default Re: HID in a stock EK housing... (Petah)
your trying to get an OEM projector set from like an audi???and puttin it in your stock EK housing/?
Old Nov 4, 2003 | 07:39 AM
length's Avatar
Default Re: HID in a stock EK housing... (96civicB20)
he don't know
Old Nov 4, 2003 | 07:42 AM
96civicB20's Avatar
Default Re: HID in a stock EK housing... (Jdm Ek Hatch)
how is your set-up....u juss got some kit that uses philips components or did u retro-fit your headlights with audi, bmw...etc projectors?
Old Nov 4, 2003 | 07:45 AM
navin's Avatar
I think "Airbag Club" did a retrofit into his EK...
Old Nov 4, 2003 | 07:53 AM
enrique's Avatar
I went with option 2 in my ek. Lighting was awesome, pattern was good.it wasn't the best it could have been because I left in the defuser since I knew I would go back to stock eventually. there is almost no room for error with going with the shield. just aim and you are good to go. I would have liked to have done a projector retrofit but I knew I wouldn't have my hatch for that much longer.
Old Nov 4, 2003 | 08:04 AM
Petah's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96civicB20 &raquo;</TD></TR><TR><TD CLASS="quote">your trying to get an OEM projector set from like an audi???and puttin it in your stock EK housing/?</TD></TR></TABLE>
I don't know what i want to do right now. I am just in the planning stage. Idealy, i would like to go with option 2 (using a OEM Lexus, BMW, TL.... kit and using the casper shield) because i like to retain the OEM look (non projector) but i would like to see some pictures of the cutoff, spread etc before going this route.
Old Nov 4, 2003 | 08:05 AM
Petah's Avatar
Default Re: HID in a stock EK housing... (enrique)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enrique &raquo;</TD></TR><TR><TD CLASS="quote">I went with option 2 in my ek. Lighting was awesome, pattern was good.it wasn't the best it could have been because I left in the defuser since I knew I would go back to stock eventually. there is almost no room for error with going with the shield. just aim and you are good to go. I would have liked to have done a projector retrofit but I knew I wouldn't have my hatch for that much longer.</TD></TR></TABLE>
What OEM kit did you use? Got some pics of the lighting? And by defuser, are you referring to the shield that is inside of the OEM headlight?
Old Nov 4, 2003 | 09:46 AM
enrique's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petah &raquo;</TD></TR><TR><TD CLASS="quote">
What OEM kit did you use? Got some pics of the lighting? And by defuser, are you referring to the shield that is inside of the OEM headlight?</TD></TR></TABLE>
sorry no pics, hd crashed. I had some OEM Honda HID's from some suv. Just go with the shields. if you don't feel they are up to what you want, which they should be, get an extra set of headlight housing and retrofit the projector. can't go wrong either way.
Old Nov 4, 2003 | 09:55 AM
6SPD_EK's Avatar
check the link in my sig - I am running http://www.autolamps-online.com (now http://www.hid-online.com) h4 hylow...i need to take more recent pics - I got the cutoff a 'lil more level then in the pics...if you aren't going to retrofit projectors, this kit is the next best thing. BTW I am running philips ultinon bulbs (6000k) also please note I am using CTR headlamps (made for RHD) which don't have the reflectors in the housing
see the same kit in Apex_i_ITR's hatch here https://honda-tech.com/zerothread?id=639146 his camera did a better job of getting the true color
for those who are lazy here is one pic
Old Nov 4, 2003 | 11:07 AM
mofo 80's Avatar
Default Re: HID in a stock EK housing... (adirondackR)
i just saw you post in my thread asking about the shields.
here's a pic of my cut off with the shield.
i think it's decent.
Old Nov 4, 2003 | 11:24 AM
96civicB20's Avatar
Default Re: HID in a stock EK housing... (**** 80)
what bulbs do u have with those shields?
Old Nov 4, 2003 | 11:52 AM
Petah's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by **** 80 &raquo;</TD></TR><TR><TD CLASS="quote">i just saw you post in my thread asking about the shields.
i think it's decent. </TD></TR></TABLE>
Thanks for everyone's response.
Mofo80; What OEM kit is that? From reading your post, you didn't modify your housing in any way.....is this a correct asumption? Also, do you have a pic of the lights on the road? I want to see the spread as well.
Old Nov 4, 2003 | 02:48 PM
mofo 80's Avatar
i have oem maxima ballast and bulbs.
i used epoxy to put the shields in the bulb. that's the only mod i had to do. i don't have any pics of the spread but there's a wider range of coverage.
Old Nov 4, 2003 | 03:10 PM
Petah's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by **** 80 &raquo;</TD></TR><TR><TD CLASS="quote">i have oem maxima ballast and bulbs.
i used epoxy to put the shields in the bulb. that's the only mod i had to do. i don't have any pics of the spread but there's a wider range of coverage. </TD></TR></TABLE>
Does it light up the road better? What about hot spots? I mean, with projectors, the light is VERY even...no one spot is brighter but with halogens, there are hot spots meaning certain parts are brighter.......i guess i am trying to ask if the light output is evenly distributed.
Old Nov 4, 2003 | 03:45 PM
mofo 80's Avatar
it def lights the road better. if you got the money, do the retrofit. if you don't, you'll still be fine.
Old Nov 4, 2003 | 03:59 PM
Petah's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by **** 80 &raquo;</TD></TR><TR><TD CLASS="quote">it def lights the road better. if you got the money, do the retrofit. if you don't, you'll still be fine. </TD></TR></TABLE>
It's not really the money.....i just don't like the projector look with the EK headlights.....it i had a EG, i will do the retrofit for sure.
Old Nov 4, 2003 | 04:33 PM
mofo 80's Avatar
you don't really need the projectors. the color and brightness will be good.
Old Nov 4, 2003 | 09:42 PM
underrated's Avatar
Does anyone have a pic with the stock diffuser taken out??? I was wondering how it would affect the light spread.
Old Nov 4, 2003 | 11:23 PM
Airbag Club's Avatar
Default Re: (underrated)
wow, someone brought up my name anyways, here are pictures of my bmw bi-xenon projectors retrofitted into my EK.
Low Beams.
High Beams.
Projection
Old Nov 4, 2003 | 11:28 PM
It's not really the money.....i just don't like the projector look with the EK headlights.....it i had a EG, i will do the retrofit for sure. </TD></TR></TABLE>
retrofitted projectors don't look that bad in EK housings. It is not very noticable, and is quite attractive. looking at the front end of the car, it looks like it has eyes. anyways, the output is amazing, and it is worth doing.
Old Nov 5, 2003 | 03:19 AM
Petah's Avatar
Default Re: HID in a stock EK housing... (Airbag Club)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Airbag Club &raquo;</TD></TR><TR><TD CLASS="quote">
What kind of projectors are they? Do you have a write up on how to do this retrofit?
EDIT: on my head! You mentioned in your first post that they are BMW bi-Xenon....but do you have a write up about the retrofit?
Modified by Petah at 4:41 AM 11/5/2003
Old Nov 5, 2003 | 03:41 AM
subzero_SiR's Avatar
i've got the option 2 in type r headlamps. I have the McCulloch 5000k kit with the shield that came with the kit....cut off is perfect and well worth the $$$.
Old Nov 5, 2003 | 04:13 AM
NeVeR bLoWn's Avatar
And people say cars dont have attitude....
i got BMW HIDs for sale, not sure on a price as of right now, since this is H-T ill try to get a little hook up for the projector as well...any one intrested?
Old Nov 5, 2003 | 08:56 AM
yee SERIOUS's Avatar
airbag club, those headlights look wicked...can i ask how you did it? step by step?
