A lil OT but still needs to be answered!
Old Nov 3, 2003 | 10:56 AM
Opie's Avatar
Default A lil OT but still needs to be answered!
My brake light is on even when my handle is down in both my R and my beater CRX.. Trey advised I check the fluid levels and just wanted to know if any fluid will work in my crx? Do i have to bleed the system if i'm just adding fluid?
I don't know if that's the prob in my R also, whereas i am @ work and can't check it. I know for sure it is the case in my CRX though...
http://www.itrca.com/forums/viewtopic.php?t=3139
Wanted to post it here because H-T moves a bit faster that ITRCA and i need some feed back on this..
Thanks opie
Old Nov 3, 2003 | 10:58 AM
Opie's Avatar
Default Re: A lil OT but still needs to be answered! (opie112)
And yes, just for clarification I am a newb and have never had to change brake fluid in any car i have ever owned!
I usually crash them before any maintenance is due!
Old Nov 3, 2003 | 11:06 AM
rizen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie112 &raquo;</TD></TR><TR><TD CLASS="quote">And yes, just for clarification I am a newb and have never had to change brake fluid in any car i have ever owned!
I usually crash them before any maintenance is due!</TD></TR></TABLE>
LOL
I had the same problem in my GSR and it ONLY did it when it was cold/damp outside. Once it warmed up (the car) the light would turn off. Do you have similar symptoms?
Old Nov 3, 2003 | 11:09 AM
thk's Avatar
thk
Members Only
It could be the reservior cap.
At least, that was the problem with my ITR. Not sure about the CRX though.
Opie's Avatar
Default Re: A lil OT but still needs to be answered! (r1zen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1zen &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem in my GSR and it ONLY did it when it was cold/damp outside. Once it warmed up (the car) the light would turn off. Do you have similar symptoms?</TD></TR></TABLE>
Yes and no. My crx light is on all the time hot or cold. In my R this happens when im leaving my girls house @ night or out driving late @ night..
Old Nov 3, 2003 | 11:10 AM
cmdr430's Avatar
just open the cap on the brake fluid and add a little. i have had the same problem before.
Old Nov 3, 2003 | 11:12 AM
rizen's Avatar
Yes and no. My crx light is on all the time hot or cold. In my R this happens when im leaving my girls house @ night or out driving late @ night..</TD></TR></TABLE>
I never had the chance to figure out the problem. Someone jacked my car...
sorry...
I just thought I was the only one with this weird problem.
Old Nov 3, 2003 | 11:13 AM
Opie's Avatar
Default Re: A lil OT but still needs to be answered! (cmdr430)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">just open the cap on the brake fluid and add a little. i have had the same problem before. </TD></TR></TABLE>
Will any fluid do the job in my CRX?
Old Nov 3, 2003 | 11:25 AM
tpr's Avatar
tpr
Dot 3 Brake fluid!
Old Nov 3, 2003 | 11:30 AM
JDMTYPER's Avatar
LOL
I have the exact same problem. Not sure why though
Old Nov 3, 2003 | 11:55 AM
mstewar's Avatar
For the R, replace the cap.. the fail on tegs notoriously.. search would've told you that..
maybe try the same on the CRX..
Old Nov 3, 2003 | 11:59 AM
Opie's Avatar
Default Re: A lil OT but still needs to be answered! (mstewar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">For the R, replace the cap.. the fail on tegs notoriously.. search would've told you that.. </TD></TR></TABLE>
That much I know, but i couldn't pull anything up on a search.
Old Nov 3, 2003 | 12:08 PM
Champ R's Avatar
I had the same problem, and my fluid levels were fine. All i did was take the cap off, clean it and put it back on. The light hasnt come back on since.
Old Nov 3, 2003 | 07:28 PM
Philly_NBP_R's Avatar
Default Re: A lil OT but still needs to be answered! (Champ R)
yup - there's a sensor in the reservoir that will make the light come on if the fluid is low (or if the sensor isn't working...)
Top up the reservoir with brake fluid and see what happens. Make sure the cap is on correctly as well...
Old Nov 3, 2003 | 08:30 PM
JDM 4 dOoR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie112 &raquo;</TD></TR><TR><TD CLASS="quote"> just wanted to know if any fluid will work in my crx? Thanks opie</TD></TR></TABLE>
i can't believe that you asked that question, you don't trust me to ask me?
big_dong861
Jan 15, 2008 01:00 PM
.1type.
10
Sep 6, 2006 09:26 PM
kornerk12
Dec 30, 2005 12:53 PM
jowy
Mar 14, 2005 05:52 PM
mi5t
Sep 7, 2004 02:03 PM
