Disconnecting Tranny from Motor
Hey, i'm rebuilding my f22a1 for some learning expierence and i was wondering if u guys knew what kind of wrench/tool i need to remove the bolts off the flywheel
they're not normal 10mm bolts or 12mm they are completely differnet and i can't find the proper kind of tool to get on them and twist them off
its the bolts connecting the tranny to the motor threw the flywheel...
if u need pics i can get some....but any suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sacredc0w69 »</TD></TR><TR><TD CLASS="quote">
they're not normal 10mm bolts or 12mm they are completely differnet</TD></TR></TABLE>
They are? I thought they were like 12 or 14 mm? Maybe im wrong
I thought all you need was a twelve star socket size 14? and I believe it is a 17 for the flywheel. Correct me if I am wrong I encountered the same problem but it was a quick fix and I don't remeber 4 sure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oday »</TD></TR><TR><TD CLASS="quote">I thought all you need was a twelve star socket size 14? and I believe it is a 17 for the flywheel. Correct me if I am wrong I encountered the same problem but it was a quick fix and I don't remeber 4 sure</TD></TR></TABLE>
it's a 12 point 19 to be exact...don't try using a regular 6 point 19 or you will strip the bolts...
Grnade
Jun 1, 2004 01:18 PM
