I found MF 10's...
Options Autosalon has Mugen wheels for sale.
They have the ones I like; MF-10 in titanium 16x7.
Now, they have two offsets; 45 and 50.
Which one is most suitable for my R?
Any input is very appreciated!
Thanks fellas!
Eric
P.S.: $495.00 a piece, including center cap. No bad?
Thanks fellas!
Eric
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AamirCWITR »</TD></TR><TR><TD CLASS="quote">+50 offset might give you problems if running wider tires such as azenis.</TD></TR></TABLE>
True that. I'm running the +50 offset and I get slight rubbing in the front passenger side when taking hard turns. I'm lowered on the Mugen Lowdons (Does Mugen still make the lowdowns by the way??).
Even with my 5 mm spacers I still get rubbing on hard turns but not as much. I just cover up the bare metal with black paint after the event it over.
On the driver side, the plastic melted from all the rubbing so rubbing is not an issue anymore on that side.
+50mm give you more clearance from the inner fender and maintains stock geometry and scrub radius.
+43mm give you more clearance from the LCA - the widest tire recommended with these is 215 section width.
I run 225 width tires on the +50mm rims no problem - but what it really depends on is the tire itself. Using Azenis as an example is misleading as they are usually wider than they say they are.
I think you are going to run into the inner fender before the LCA - but that's my opinion.
lazybrown187
Apr 9, 2007 10:11 PM
lazybrown187
Northern California (Sales)
11
Aug 15, 2006 03:52 AM
lazybrown187
Aug 14, 2006 05:05 PM
