88-89 90-91 crx fenders interchangable??
are the 88-89 crx fenders interchangable with the 90-91 crx fenders?? i'm in need for a driver side fender for my rex..and all i could find in my local junkyards are 88-89 fenders..TIA..
I hope you guys dont mind me asking a question related to this topic
so if you were to put these screw plugs from the 90-91 fender on the 88-89 fender then you could use the corner lights from the 90-1 on the 88-9 right?
Yes you can put the nicer 90/91 corners on with the clips but to properly put the corner light on you will need 90/91 headlight bezels due to the top screw on the 90/91 corners. I am sure you could still figure out another way to make it work though.
You could use a 89+ door but some parts will need to be swapped and the seatbelts will need to be tooken off the 89+ doors since they are door mounted and yours are piller mounted. I would find a 88 door if I were you since they are lighter due to no seatbelts or safety beam. All 88's and I believe in 89 the hfs still had piller mounts you want.
crxaddikt
10
Oct 21, 2013 12:22 AM
acmoc
Dec 13, 2008 12:30 PM
