Dyno, what gear to use
Old Nov 2, 2003 | 08:02 PM
rsmotors's Avatar
Default Dyno, what gear to use
To you dyno pros.
How do you know what gear to use to dyno the car?
Does it matter if you use 3rd or 4th?
Old Nov 2, 2003 | 08:39 PM
dmotoguy's Avatar
Default Re: Dyno, what gear to use (rsmotors)
third unless you cant get traction, then use 4th.. it will do the same no matter what gear though
Old Nov 3, 2003 | 07:16 AM
roadawg's Avatar
Default Re: Dyno, what gear to use (dmotoguy)
It does matter what gear is used on the dyno. The object is to use a gear ratio that is as close to 1:1 as possible.
And since most of the time 4th gear is the closest gear to having a 1:1 ratio. This simply means that for every one time the engine spins, the wheels will spin once.
Old Nov 3, 2003 | 07:43 AM
Targa250R's Avatar
be professional
Default Re: Dyno, what gear to use (hybrid honda)
Doesn't matter what gear, the difference measured between gears on the dyno is negligible. Your dyno operator will probably tell you what gear to use anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid honda &raquo;</TD></TR><TR><TD CLASS="quote">It does matter what gear is used on the dyno. The object is to use a gear ratio that is as close to 1:1 as possible.
And since most of the time 4th gear is the closest gear to having a 1:1 ratio. This simply means that for every one time the engine spins, the wheels will spin once. </TD></TR></TABLE>
No it doesn't. Think about it for a minute. Hint: final drive ratio.
b16_madman's Avatar
I did mine in 4th.
Not many mods, but that's what they told me to use it in.
1st gen b16, spoon vtec cont.,hks intake, custom 2.5" exh. stock cat., timing set at 17 deg.
one timer of 159hp @ wheels.
Yah I'm braggin'
NOTE: They also asked for the weight of the car + driver. Don't memeber what I said 2300? or 2200?
Modified by B16_madman at 10:08 AM 11/4/2003
Old Nov 3, 2003 | 08:03 AM
USDM 4G VTEC's Avatar
And since most of the time 4th gear is the closest gear to having a 1:1 ratio. T</TD></TR></TABLE>
ALL that info is correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid honda &raquo;</TD></TR><TR><TD CLASS="quote">simply means that for every one time the engine spins, the wheels will spin once. </TD></TR></TABLE>
that one actually isnt.
Old Nov 3, 2003 | 08:04 AM
Default Re: Dyno, what gear to use (B16_madman)
my cousins B16 with just exhaust no intake, no headers just a cone filter, FPR just pulled 158 whp with a Zdyne 4 days ago....
Old Nov 3, 2003 | 08:06 AM
keithv's Avatar
Default Re: Dyno, what gear to use (USDM 4G VTEC)
I always use 4th gear as it seems to give more accurate (read: actual) readings. 3rd gear pulls alway result in a higher HP number.
Old Nov 3, 2003 | 08:09 AM
Default Re: Dyno, what gear to use (keithv)
also besides having the the engine and tranny in a 1:1 ratio
the tech needs also to set the dyno into reading a specific ratio... on my dynos the RPM=3.07
Old Nov 10, 2003 | 07:49 PM
rsmotors's Avatar
thanks for the knowledge
dynoed at 186hp 148 torque
Old Nov 10, 2003 | 07:52 PM
89s1's Avatar
Default Re: (rsmotors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsmotors &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the knowledge
dynoed at 186hp 148 torque</TD></TR></TABLE>
what setup? n/a?
racinskittle
Jan 24, 2004 11:58 AM
2000vsm
Oct 11, 2003 10:33 AM
patdemps
Sep 19, 2003 01:56 PM
Maxime
Jul 25, 2002 10:50 AM
4doorH22
Sep 7, 2001 10:24 AM
