just some observations of my car...toda reliabilty, daily driving, etc
Old Nov 2, 2003 | 06:22 PM
[tk4L] Doke's Avatar
Default just some observations of my car...toda reliabilty, daily driving, etc
Well after going out of town for the 4th out of 5 weekends...i have put 3k miles on my car in the last month...might not sound like too much but for someone whos full time in college its not bad at all...my car runs very well and i have had no problems..i have been running the cams since 39k miles and my car now has 46k on it...i also bought the cams used...the whp i put down on my car wasnt what i wanted but i believe that i was because of a few problems...when i went to the exhaust shop..they didnt have a 3" flange (my dc jdm was made out to 3" or so) so the mechanic had to place a pipe inside of it so it could fit the high flow SS cat..which then goes to Tanabe 2.5" piping to the Mugen twinloop...that, the stock intake manifold, and my crankpulley being wobbly (which is being replaced this week) i think is the reason i might be loosing some power..i put down 167/123..what do you think? In conclusion..im just answering some questions people have about reliability with these cams..even though im still running basically stock compression...it's definently very reliable..tuning is probably the key to that...the making 350miles to a tank is just a plus New intake mani, port/polish, compression are all in the future.
00 Civic Si chasis
98 b18c
Toda B's
Toda camgears
Toda valvetrain
Portflow Ti. retainers
Mugen headgasket
Hondata IM Gasket
DC JDM 4-1 SS header
AEM intake
Tanabe 2.5" piping
Mugen twin-loop axleback
Highflow SS cat
Hondata S100
heres a video...its dark i know but at least you can hear her (must have divx codec)
http://www.animusnet.com/sung/s2000vsmatt.mpg
*this was done in August so its older..at the time every problem i listed above was present and my intake air sensor is not plugged in still(shouldnt make too much of a difference anyways)* Picture may take some time to load.
Modified by NAsty coupey at 11:21 PM 11/2/2003
Modified by NAsty coupey at 11:24 PM 11/2/2003
Modified by NAsty coupey at 1:59 PM 11/3/2003
Old Nov 2, 2003 | 06:55 PM
user 996328629's Avatar
Default Re: just some observations of my car...toda reliabilty, daily driving, etc (NAsty coupey)
I say all those probs, and the lack of compression for those cams to really shine. Get a good 11:5+ and youll be well on ur way
Old Nov 2, 2003 | 09:26 PM
yeer's Avatar
Default Re: just some observations of my car...toda reliabilty, daily driving, etc (Swags04)
yo matt, whos s2k was u running against? mikes?
Old Nov 2, 2003 | 09:30 PM
Chemicalviper's Avatar
toda spec ... which one ?
Most of the higher ones your gonna need an upgraded valve train and higher comp for maximum performance.
Old Nov 2, 2003 | 10:50 PM
Downey's Avatar
u have a 98 GSR? with all those mods and are only making 167? sounds like somthing up. my friends 00 GSR (all stock, just AEM) made 157/118
definetly get that crank pullet sorted out? u sure its been torqued down corrctly? 1st tighten it to 145 ft lbs. then losen it.. then retighten it to 130 ft lbs.
Old Nov 3, 2003 | 05:30 AM
Default Re: just some observations of my car...toda reliabilty, daily driving, etc (Downey)
Yea my mechanic at honda checked it out and he tightened it all the way..still is wobley..hope my cranks not bent
Old Nov 3, 2003 | 05:47 AM
Mr Hammond's Avatar
a/k/a Jomo
Tuning of A/F seems to be pretty good. I would just work on your bolt-on's. Heck we made those numbers with bolt-on's. Not to discurage, just letting you know. You have a worked 3" collector w/ a pipe stuck in it (dont' know how leak proof that is) running through a 2.5" cat through 2.36" piping and then a Mugen twin looop muffler. I'd start there with a nice header even a Header-Tech or AN-R street would be a vast improvement with a true 2.5" cat back, T/B and IM would be good as well and re tuning.
Old Nov 3, 2003 | 10:00 AM
Default Re: just some observations of my car...toda reliabilty, daily driving, etc (Mr Milano)
yea, i hope the fixed pulley helps some.
Old Nov 3, 2003 | 02:04 PM
Default Re: just some observations of my car...toda reliabilty, daily driving, etc (yeer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeer &raquo;</TD></TR><TR><TD CLASS="quote">
Im supprised you could tell what it even was haha...it was some guy at virginia tech..sick looking s2k with black volks.
Old Nov 3, 2003 | 05:56 PM
hmm...
Old Nov 4, 2003 | 07:24 AM
Default Re: (Chemicalviper)
Thinking of selling my twin loop soon and getting something with more straight through flow...hmm..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chemicalviper &raquo;</TD></TR><TR><TD CLASS="quote">toda spec ... which one ?
Most of the higher ones your gonna need an upgraded valve train and higher comp for maximum performance.</TD></TR></TABLE>
Toda b's and i do have the valvetrain..read it please.
Old Nov 5, 2003 | 07:18 AM
cant decide....ttt.
Old Nov 5, 2003 | 07:29 AM
lsvtec hatch05's Avatar
you need some pistons and possibly some rods for sure
Old Nov 5, 2003 | 08:11 AM
Default Re: (lsvtec hatch05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec hatch05 &raquo;</TD></TR><TR><TD CLASS="quote">you need some pistons and possibly some rods for sure</TD></TR></TABLE>
Yea im definently going with an ls block and alittle bore.
Old Nov 5, 2003 | 09:44 AM
Project SSAP1's Avatar
humm lets c..first off for toda b's i u def need way more compression...u most likely have about 10:3 now with that mugen headgasket...i say u need at least 11:5 with those cams...if u want to keep the stock intake mani i think its cool..esp with all the nice midrange with those cams...if u get the skunk2 u should def notice some high end power..a lil..and your exhaust flow is def outa wack...jdm dc isnt bad..but that 3" flange then all the other bottlenecks r probably killlin..get a nice full 2.5" with free flowing cat or test pipe...soem more tunning and u should b good...also r u using the toda or power timing belt..if not go get it now!!
gringotegra
114
Aug 15, 2013 04:14 AM
pootie.teng
12
Mar 5, 2008 04:57 AM
PROJECT 91
Dec 30, 2005 12:27 PM
lude69
Nov 18, 2002 06:17 PM
Project X
Aug 18, 2002 09:50 PM
