Poor mans Itr setup questions.
Old Nov 2, 2003 | 05:26 PM
soloteg's Avatar
Default Poor mans Itr setup questions.
I already did a search and did not find what i wanted. I currently have a b16a with a shaved hade and bad rings on the bottom end. Is it still possible to use a shaved b16a with a b18c bottom end?
Old Nov 2, 2003 | 05:32 PM
B16GSR's Avatar
Default Re: Poor mans Itr setup questions. (soloteg)
yes
Old Dec 30, 2003 | 03:30 PM
Grandprix's Avatar
Default Re: Poor mans Itr setup questions. (B16GSR)
Quick Question.
When you swap on a b16 head to your GSR integra, what fuel injectors do you use?? So how does that affect your ECU (chip) choices?
Old Dec 30, 2003 | 04:18 PM
FerioVtec94's Avatar
both gsr and b16 use the same injectors, 240s
Old Feb 25, 2004 | 06:25 PM
Icey112's Avatar
Default Re: (FerioVtec94)
yes
Old Feb 25, 2004 | 07:04 PM
JDMvtecDRAGSTA's Avatar
Default Re: (Icey112)
still possible but u should invest a little more money into into rebuilding the block with new bearings and get some pistons w/new pistons rings
if u dont wanna invest, yah that combo u mentioned will work
fv8s
Dec 15, 2009 09:56 PM
94civic18
Dec 13, 2007 09:30 AM
JDM_EK4_Coupe
Jun 27, 2007 08:42 PM
ReV LiMiT
Mar 20, 2004 05:05 AM
dc-lefty
Mar 2, 2004 08:33 AM
