10.1 compression in a stock gsr
Old Nov 2, 2003 | 02:25 PM
cstay's Avatar
Default 10.1 compression in a stock gsr
should i run a 2 layer head gasket in the motor i am gona swap in with stock cams. im only gona run the set up for 1 summer because 3rd semester we need to do a motor rebuild project. but i wanted to be a little bit more spunkey for the summer.
Old Nov 2, 2003 | 03:28 PM
Project SSAP1's Avatar
Default Re: 10.1 compression in a stock gsr (cstay)
go for it...im thinkin about doin the same thing with my gsr...i would pick from either spoon, mugen, cometic..just make sure u seal everything back or u could have issues lata on
Old Nov 2, 2003 | 04:01 PM
cstay's Avatar
Default Re: 10.1 compression in a stock gsr (Project H22DC4)
what kind of numbers do u think i will get?
Old Nov 2, 2003 | 05:13 PM
not really sure..dont think it will help that much..i mean the stock gsr is 10:1 so the gasket will only raise comp by .2-.3 or something like that..so if u want more gains i would get some JDM ITR pistons and then use the gasket...but of course this will cost a hell of a lot more doe..so unless u have to change the headgasket i wouldnt bother with it cause it wont make that much of a difference
Old Nov 3, 2003 | 12:42 AM
hondamotorco's Avatar
Use a OEM Honda headgasket, and remove a layer. Put in some B16 pistons too.
Old Nov 3, 2003 | 02:37 AM
Downey's Avatar
Default Re: (hondamotorco)
are you sure its safe, to just remove a layer? arent they 3 layer for a purpose?
Old Nov 3, 2003 | 09:14 AM
cstay's Avatar
Default Re: (Downey)
i dont think i am gona do aneything. i was gona bump it up just for the summer so i could have a little more kick until my third semester rebuild. I dont think its gona be worth it tho.
Old Nov 3, 2003 | 12:41 PM
Kataku2K3's Avatar
Default Re: (cstay)
That's probably a good choice... I personally will not mess with a motors compression via changing headgasket or milling... If you wanna bump up the C/R do so with pistons... Yea, it costs more but it's the only way to really do it... As stated above at std. bore (81.00mm in your case) you'll get about a 0.25:1 increase for every 0.009-0.010" you pull off... Even going down to a single layer, increasing your C/R by roughy 0.50:1 you probably won't notice any gains... All motor is all about headwork and cams... Getting the compression is the easy part... Just my $0.02... peace
Old Nov 3, 2003 | 06:30 PM
riceball777's Avatar
i would only use a oem head gasket
and get a 2 layer head gasket really wont help much
your not going to feel any difference if thats the only thing your going to go
boostd ls
Jan 16, 2006 10:57 PM
tunedek
Jul 20, 2004 05:15 PM
jazz1320
Mar 13, 2004 10:57 AM
JunIntegra
14
Jan 10, 2004 02:19 PM
integra-modder
Aug 3, 2002 02:50 AM
