Harmonic vibrations
Old Nov 2, 2003 | 03:28 AM
88 rex's Avatar
Default Harmonic vibrations
My car is making a sound like when you rim a glass...I've never heard it before on any other car, but its pretty loud and sounds almost exactly like ******* a glass. It sounds like something is somewhat dry or low on fluids, but my oil is fine. I cant exactly pinpoint the exact spot of the sound and it sends vibrations throughout the transmission and i can feel it on the stick, also somewhat with my feet. Is it possible that i'm low of tranny fluid? I would check but i'm not with my car this weekend and am just hoping that this could be it so i know to check as soon as i get back.
Thanks
Will
Old Nov 2, 2003 | 04:22 AM
Fobtions's Avatar
Default Re: Harmonic vibrations (88 rex)
it can be that you are low on tranny fluid, or the tranny itself might be goin bad. also check your wheel bearings and axles.
Old Nov 2, 2003 | 04:41 AM
davens's Avatar
I've heard bearings make that kind of sound as they go bad...and there being several bearings in the transmission and that being a source of vibration...sound like tranny work.
Check the fluid, if it's low top it off and hope for the best but if it's already making noise, it's probably already jacked up.
Then you repair or replace...neither being cheap or easy
Old Nov 2, 2003 | 05:40 AM
Fobtions's Avatar
Default Re: (davens)
yah this is true. my diff bearings are shot and somewhut sound like his description,
Pr0jektLude
Jun 12, 2004 04:50 PM
deviant94ex
13
Jan 11, 2004 04:54 PM
CivicNewbie
Jul 31, 2003 08:58 PM
DsMWookie
Feb 20, 2003 02:16 PM
01-1293
Jul 12, 2002 11:11 AM
