best 125$ bucks I've spent on my turbo setup, good tires and poly filler
I just got a pair of falken azenis and the grip like a rock. I was running on some bfg, but they could hold first or second gear. These bitches grip. I also got some polyurthien (ms) glue **** for my motor moutns. It was funny because after I got the new tires my motor boucing more because of my shitty mounts.
Two thumbs up Falken Azenis sports tires! btw I heard these tires are d.o.t. drag radials is that true?
Nick
Nick
with the poly motor mounts - it fixed my clutch not engaging. Mista bone told me that could be the reason why my 2-3 shift would grind and he was correct.
The new tires make mounts worse. So I filled them and I let it set over night. btw I filled the mounts on the car. I used tape as a border to keep the gue inside. I only filled them on the bottom of them with poly stuff. The filler was around $2.50 at lowes
Nick
Nick
I'm not sure if we are using the same thing but I have, liquid polyurethane in my mounts and it's as hard as normal polyurethane. Mine was $10 from an autobody and paint shop. This stuff is hard to work with but worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS »</TD></TR><TR><TD CLASS="quote">I wonder how this "fill" compares to actual inserts? I put the inserts in and hate them! maybe next week when the turbo goes on and i start making some real power i will appreciate them.......</TD></TR></TABLE>
what's the reason why you hate them?
to polyurethane.
