activating vtech?
Old Nov 1, 2003 | 06:19 PM
93slmdcvcsi's Avatar
Default activating vtech?
Has anyone ever used a shift light to activate vtech?.... if so, what is needed to use the shift light from autometer?
Old Nov 1, 2003 | 06:27 PM
Steve90HB's Avatar
Default Re: activating vtech? (89cvchb)
http://www.geocities.com/motor....html
searching usually helps, it requires wiring... probably didnt find anything cuz it's spelled VTEC
Old Nov 1, 2003 | 06:31 PM
Default Re: activating vtech? (Steve90HB)
well first of all that link that was given doesn't say anything about wiring vtec up to a shift light
Old Nov 1, 2003 | 06:49 PM
SMZ GSR's Avatar
My phone usually works by just plugging it in..
VTEC is in Hondas
VTECH is a phone!
As for your question, there is no way in hell to have a shift light engage VTEC
Old Nov 1, 2003 | 08:54 PM
krazeemidget's Avatar
dont use a shiftlight use a RPM switch..it worked for me
Old Nov 2, 2003 | 05:54 AM
CRX_VTEC's Avatar
Default Re: activating vtech? (krazeemidget)
activating vtec manually does you no good. Just because your vtec kicks in doesnt mean the fuel system is too. MSD had vtec activation and rpm pills you could use...but the whole "shift light to activate vtec" thing played out back in 1995....get with the times man.
Old Nov 2, 2003 | 06:47 AM
91civicDXdude's Avatar
a shift light is essential an rpm activated circuit wired to a light. it is in no way "played out". it is a legitimate way to activate any 12v signal via rpm. Basically, rewire the light output to the VTEC solenoid. and BTW, just becuase you have an rpm activated switch doesnt mean that you dont have an AFC or a chipped ECU or something to control the additional fuel and timing curves required for proper tuning of the high cam lobes.
Old Nov 2, 2003 | 10:16 AM
kranked91dx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89cvchb &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone ever used a shift light to activate vtech?.... if so, what is needed to use the shift light from autometer? </TD></TR></TABLE>
yep you can, simply wire your **** light to a relay, this one will engage vtec, it's getho but work f* great.
KRanked
Old Nov 2, 2003 | 11:34 AM
firstgenrex's Avatar
it'll work, its a dam good idea, i say if maybe u could splice em up, it would be tight that when vtec kicks in, the light would go on and saty on until the vtec is off. its continous power so it would work fine. if u wanna get really ghetto, get a toggle switch. im not sure about how good for the solenoid it is.. ive heard it will fry it eventually.. but use shift light until u can saver enough cash for an obd1 change and use the rioght computer or get ur si computer redone
Old Nov 2, 2003 | 06:34 PM
CRX_VTEC's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">BTW, just becuase you have an rpm activated switch doesnt mean that you dont have an AFC or a chipped ECU or something to control the additional fuel and timing curves required for proper tuning of the high cam lobes.</TD></TR></TABLE>
But if you have that then whats the point of the ghetto rig? Anyone that has the right ECU shouldnt be rigging any "manual" activation switch anyway. What purpose would it serve?
Old Nov 2, 2003 | 08:00 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (CRX_VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
But if you have that then whats the point of the ghetto rig? Anyone that has the right ECU shouldnt be rigging any "manual" activation switch anyway. What purpose would it serve?</TD></TR></TABLE>
probally to get more VtEc yO!
Old Nov 2, 2003 | 09:18 PM
probably to use an OBD0 setup without a PR3/PW0 ECU, smartass.
Old Nov 3, 2003 | 07:26 AM
Limited S.L.I.P.'s Avatar
I am currently using a shift light to engage vtec, havent had any problems. I'd still recommend a vtec controller.. my car is a commuter and I'm not really looking to dump money into it so the light works fine
crooked muffler
29
Oct 17, 2018 04:54 PM
ls weez
Jul 11, 2006 08:34 PM
4dohs4mohoes
Sep 28, 2002 06:30 PM
photonjedi808
19
Aug 30, 2002 08:07 AM
