Help... Front pass. tire has a lot more wear than any other tire? Why?
Old Sep 6, 2001 | 03:10 PM
OneThirtyEight's Avatar
Default Help... Front pass. tire has a lot more wear than any other tire? Why?
Ok, My front pass. tire is signifignatly lower tread than my drivers front, or any of the backs. This is Really strange. I have the eibach pro-kit and nitto 555's for tires. Why would one of my drive tires be signifignatly more worn than my other? I would say pass tire has about 4k life left, while drivers front looks liek it has abotu 10-15k left... very strange.
Old Sep 6, 2001 | 03:43 PM
GS Type R's Avatar
New User
Default Re: Help... Front pass. tire has a lot more wear than any other tire? Why? (97blackteg)
have you ever rotated your tires? is the pressure low on that side? no,yes, well then with any front wheel drive car the pass. side will always wear first because it has the shorter axle so that side will spin before the driver side.
My advise is dont peelout so much and rotate your tires every 5000 miles and keep the pressure @ 33-38lbs.
Old Sep 6, 2001 | 03:46 PM
HX_Guy's Avatar
Default Re: Help... Front pass. tire has a lot more wear than any other tire? Why? (GS Type R)
Yea mine is the same way. I think its due to the fact that on our cars the passanger side wheel is the one "driven" by the transmission. When you do a burnout for example...the passanger wheel spins while the drIver's doesnt (unless you have LSD).
Old Sep 6, 2001 | 04:36 PM
Default Re: Help... Front pass. tire has a lot more wear than any other tire? Why? (HX_Guy)
ah that anwsers my question. Thanks.
Old Sep 6, 2001 | 08:58 PM
Slain's Avatar
maybe just maybe it could be a alignment problem causing the premature wear otherwise the guys are right
[Modified by Slain, 5:58 AM 9/7/2001]
supadupamikey's Avatar
Default Re: Help... Front pass. tire has a lot more wear than any other tire? Why? (Slain)
one-wheely peelies?
Old Sep 6, 2001 | 10:28 PM
kikkoboyie's Avatar
New User
Default Re: Help... Front pass. tire has a lot more wear than any other tire? Why? (lilmikey77)
i got the pro kit 2... yikes
how come when we peel out, on the passanger side spins?????? curious....
Old Sep 7, 2001 | 08:31 AM
GSG2's Avatar
check ur alignment. a messed up toe will wear out the tires faster. i got mine aligned and the driver side was waaaay out of the toe specified for the car. mine was on the driver side though. peeling out was minimal.
[Modified by jobau, 9:35 AM 9/7/2001]
parsapour
Jan 6, 2019 12:35 PM
SlowDriver74
Nov 17, 2011 01:40 PM
riceburners1
Mar 23, 2004 07:28 PM
Loen
May 1, 2002 04:22 AM
