Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Floor jack that'll go under a 3" frame?
Old Nov 1, 2003 | 02:53 PM
kb58's Avatar
Banned
Default Floor jack that'll go under a 3" frame?
Anyone know of one? Most I see only go down to 5.5" or so. I'm lifting 1000lbs max.
Old Nov 1, 2003 | 03:08 PM
combustion's Avatar
Default Re: Floor jack that'll go under a 3" frame? (kb58)
scissor jack....
No i believe that crafstman had a aluminum jack that sat real low
Old Nov 1, 2003 | 03:14 PM
nonsense's Avatar
harbor freight has one that goes down to 3.5" and Craftsman makes one that goes down to 3.75"
You can always drive up on a 2x8x12" piece of wood first.
Old Nov 1, 2003 | 03:20 PM
kb58's Avatar
Banned
Default Re: Floor jack that'll go under a 3" frame? (nonsense)
Yeah... I came back to update this thread. I was just at Harbor Freight, and while they had aluminum jacks, they didn't have this one shown on their site:
http://www.harborfreight.com/c...40105
And what's with the "nonsense"...
Old Nov 1, 2003 | 04:16 PM
Another Drew's Avatar
Just about at 3 inches. It's a very nice quality jack.
http://www.ultimategarage.com/acjacks.html
Old Nov 1, 2003 | 04:58 PM
kb58's Avatar
Banned
Default Re: Floor jack that'll go under a 3" frame? (Another Drew)
Thanks. I've seen this site before but didn't remember they sell jacks. Very nice... but a bit pricy for me. Interesting their site says a nice aluminum race jack is the right piece of equipment to pack in the trunk or trailer for the event. Expect to pay $800-1100 for a high quality professional jack
Guess they don't want to know about the $139 jack...
I suppose another approach is to weld in jacking points >5.5" high...
Old Nov 1, 2003 | 05:01 PM
RineRacing's Avatar
You can also get blocks of wood to drive onto to raise the car enough.
Old Nov 1, 2003 | 06:27 PM
Mista Bone's Avatar
D Tranny Guru
make a hook adapter to fit into the saddle, goes as low as 3/4".......
You should have seen the jack Jamie Houseman was using.......
Old Nov 1, 2003 | 07:33 PM
Vitt1's Avatar
What part of CA do you live in? I thought HF carries basically 2 aluminum jacks, 3000 and 4000 lb, except for color. The Harbor Freight in Pasadena had the small jacks last time I was there, but at a higher price. I was told if I print out the ad for a product from the website, the store would honor that price, but double check with your local store.
Old Nov 2, 2003 | 02:37 PM
turbohappy's Avatar
The AC jacks are awesome and all of them go down to 3.1".
http://www.asedeals.com/hydraulicjacks2.html
Old Nov 2, 2003 | 02:42 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 &raquo;</TD></TR><TR><TD CLASS="quote">And what's with the "nonsense"...</TD></TR></TABLE>
It's been my username since about 1996-97 ish. I couldn't think of a username for my e-mail that wasn't already taken. I decided that I might as well think of a name that made no sense because it would probably not be taken. The username has stuck ever since. It really doesn't make sense to me why I keep it either.
Steve
Old Nov 2, 2003 | 03:26 PM
slowhtwgn's Avatar
Default Re: Floor jack that'll go under a 3" frame? (turbohappy)
As stue as it is, they also weigh close to two times as much as the Harbor Freight's jack - something to think about if you're planning on carying the jact with you to many events.
Specifications:...........DK20...........DK13HLQ.. .......Herbor Freight
Capacity...................4400 lbs.......2900 lbs...........3000 lbs.
Min. Height ...............3.1".............3.1".............. ...3.5''
Max. Height...............19.7"...........29.2"........ ........17-1/2''
Frame Length............26"..............32"............ .......23.62''
Handle......................37.4"...........37.4". ...............47-1/4''
Frame Height ............6.3".............6.3"................. 6.1''
Width........................16"..............18.9 "...............11.81''
Weight......................64.5lbs.........84.7lb s............35.40 lbs
Herbor Freight's jack also needs only "6 pumps and requires only 1/2 turn to release for lightning fast pit stops" - as listed on the site.
Hope this helps
Old Nov 2, 2003 | 04:59 PM
kb58's Avatar
Banned
Default Re: Floor jack that'll go under a 3" frame? (slowhtwgn)
Thanks guys. Looks like I'll visit HF again with a copy of the jack from their website...
Old Nov 2, 2003 | 08:51 PM
Vitt1's Avatar
Not sure if this link is a repost, but it has some good info on jacks, including a couple mentioned on this thread:
http://www.vorshlag.com/tech_jacks1.asp
Old Nov 2, 2003 | 09:46 PM
slowhtwgn's Avatar
Default Re: Floor jack that'll go under a 3" frame? (Vitt1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vitt1 &raquo;</TD></TR><TR><TD CLASS="quote">Not sure if this link is a repost, but it has some good info on jacks, including a couple mentioned on this thread:
I forgot all about this article. Great catch!
Old Nov 3, 2003 | 08:47 AM
turbohappy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowhtwgn &raquo;</TD></TR><TR><TD CLASS="quote">As stue as it is, they also weigh close to two times as much as the Harbor Freight's jack - something to think about if you're planning on carying the jact with you to many events.</TD></TR></TABLE>
Yeah, he didn't say if it was for home or track use. I'd go with the HF or the new Craftsman for track use
Old Nov 3, 2003 | 06:46 PM
kb58's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohappy &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, he didn't say if it was for home or track use. I'd go with the HF or the new Craftsman for track use </TD></TR></TABLE>
Both. I'm holding off for the moment, deciding if I want to devise some sort of screw jacks on the car... If so I could use a CO2 cylinder air-powered impact wrench to raise/lower the car, in addition to changing tires...
Old Nov 3, 2003 | 06:49 PM
eliktronik's Avatar
You should just integrate a few pheumatic bottle jacks into your chassis, just like the pro's. :D
Old Nov 3, 2003 | 08:11 PM
kb58's Avatar
Banned
Default Re: Floor jack that'll go under a 3" frame? (eliktronik)
They cost money... though I could make them easy enough. Screw jacks OTOH give a better feeling of safety if I need to get under it...
Old Nov 4, 2003 | 08:28 AM
TodaSi's Avatar
AC is my jack of choice
I would use the Harbor Freight aluminum jack for races only
Old Nov 7, 2003 | 12:29 PM
Better price for the same jack.......$99.99
http://www.softwareandstuff.co....html
At least I think it's the same jack. The specs are almost identical.
Old Nov 7, 2003 | 12:50 PM
Tyson's Avatar
its pretty ridiculous how cheap these things are now. oh well. its served me very well. had to replace a lost bolt holding the front roller, no big deal.
Old Nov 7, 2003 | 12:56 PM
RineRacing's Avatar
Default Re: Floor jack that'll go under a 3" frame? (Tyson)
I remember when I was happy to buy one for $200.
Who bought the HF jack before it was cool to own one
Old Nov 7, 2003 | 01:06 PM
Tyson's Avatar
Default Re: Floor jack that'll go under a 3" frame? (Geratol)
told you about HF jack.
Old Nov 7, 2003 | 02:23 PM
Vitt1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Another Drew &raquo;</TD></TR><TR><TD CLASS="quote">Better price for the same jack.......$99.99
At least I think it's the same jack. The specs are almost identical.</TD></TR></TABLE>
They look pretty much the same. I'd still go for the HF because I can buy a 2 year extended warranty for that jack for about $11.
