H22a-T in 5th gen Questions
Old Nov 1, 2003 | 11:42 AM
TypeRKoncepts's Avatar
Default H22a-T in 5th gen Questions
I was just wondering about some stuff for my setup that i am planning.
Has anyone ran into intercooler piping issues on their turbo accords? i have the factory bumper, any clearance issues to be worried about?
Also what size (dimensions) intercoolers do you run, i'lll be looking for an intercooler that supports approximately 400 hp.
I've heard of H22a's using stock cams in the very high boost range, is this possible with stock cams or is it only possible with stock cams that are modified? I was thinking of getting the skunk2 stage 2's but the price is pretty damn steep...
Thanks
Old Nov 1, 2003 | 12:21 PM
M.A.R.C.'s Avatar
Default Re: H22a-T in 5th gen Questions (TypeRKoncepts)
h22a's sux0rz!!!! lol j/k sid. bump for mah homie
Old Nov 1, 2003 | 12:50 PM
m0t0rhead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRKoncepts &raquo;</TD></TR><TR><TD CLASS="quote">I was just wondering about some stuff for my setup that i am planning.
Thanks
Skunk2 stage 2's ? I would think they have too much overlap for a boosted application. Look for some good boost cams.
Old Nov 1, 2003 | 01:50 PM
KTeller8's Avatar
Default Re: H22a-T in 5th gen Questions (Escobar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Escobar &raquo;</TD></TR><TR><TD CLASS="quote">
Skunk2 stage 2's ? I would think they have too much overlap for a boosted application. Look for some good boost cams.</TD></TR></TABLE>
Yes by far they are a NA cam.. id go with some FI regrinds or go with some Turbo Cams.. check out http://www.ef-1.com if anyone can do the regrind and make them better then what you ll ever expect its Rocket over there, only down fall would be the wait right now
Old Nov 1, 2003 | 01:51 PM
KTeller8's Avatar
Default Re: H22a-T in 5th gen Questions (KTeller8).
as far as the IC piping, thats not a problem, the motor sits almost the same as the F22, so the piping would be routed like every other accord with turbo:
Drag FMIC might work up to your HP, if not, go with a jdm version or a Spearco core
if you guys want to boost big and run big FMIC's your going to have to do a little dirty work and cut your bumpers a tad
Old Nov 1, 2003 | 02:24 PM
M.A.R.C.'s Avatar
Default Re: H22a-T in 5th gen Questions (KTeller8). (KTeller8)
doesn't skunk make a turbo cam as well? coulda sworn i heard that the other day... could be wrong though
Old Nov 2, 2003 | 08:24 AM
lmblf8's Avatar
woo, go FL people.
Couple days ago I heard that someone just order Skunk turbo cams, but they aren't online. hmm?
Old Nov 2, 2003 | 12:27 PM
Thanks for the info guys, appreciate it.
I'm a newb when it comes to building motors, but i'll check out skunk2 turbo cams and others this comming week. My main concern is my idle when it comes to daily driving on low boost, which is why i figured stage 2 will be much better for a mild setup than straight turbo cams.
Old Nov 2, 2003 | 12:36 PM
97F22B2's Avatar
a Tyrus FMIC would be good for your Accord like mine. Thye amke them slender for our bumper supports. But KTeller might have some good hookups.
Old Nov 2, 2003 | 03:44 PM
M.A.R.C.'s Avatar
Default Re: (lmblf8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmblf8 &raquo;</TD></TR><TR><TD CLASS="quote">woo, go FL people.
Couple days ago I heard that someone just order Skunk turbo cams, but they aren't online. hmm?</TD></TR></TABLE>
Old Nov 2, 2003 | 10:22 PM
matix's Avatar
one of topic ques whats the best honda junkyard down south?
Old Nov 3, 2003 | 01:13 AM
KTeller8's Avatar
Default Re: (CivicRyda2k)
depends what car .. last i heard they were going to be out, but also heard that skunk2 was going to put out the h22 manifold.. and that was almost year ago.. who knows.. i dont think they are out.. but might be?
Old Nov 3, 2003 | 04:18 AM
I'll contact skunk2 today and ask about that. I was thinking of going with the venom or str manifolds though, any of you guys have an experience with them?
As for best junkyard down south - I haven't found anything really decent in the Broward County area... most junkyards either already have everything even remotely useable stripped or have crap pre-90's cars.
Old Nov 3, 2003 | 04:24 AM
KTeller8's Avatar
Default Re: (TypeRKoncepts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRKoncepts &raquo;</TD></TR><TR><TD CLASS="quote">I'll contact skunk2 today and ask about that. I was thinking of going with the venom or str manifolds though, any of you guys have an experience with them?
As for best junkyard down south - I haven't found anything really decent in the Broward County area... most junkyards either already have everything even remotely useable stripped or have crap pre-90's cars. </TD></TR></TABLE>
I had the Venon for my h22, it was a nice idea and item, but it sold around 475-525, i dont think that it was the best thing for the $$, plus you lost all secondary runners and IAB's... so i would of went from P13/P72 to a P28 ecu..
Old Nov 3, 2003 | 09:35 PM
Nick H's Avatar
New User
if anything, a turbo cam will give you a much better idle than a stage 2 cam would...it's the crazy profiled N/A cams that give you a shitty idle...just thought you should know that before you regret getting stage 2 cams instead of a turbo cam...
Old Nov 4, 2003 | 05:48 AM
m0t0rhead's Avatar
Default Re: (Nick H)
I've had luck with stage 2's on a NA car. A fuel computer will help your idle as will raising it a couple hundred rpm.
It would be stupid to use a NA cam on a turbo'd motor.
Old Nov 4, 2003 | 11:36 AM
Welp i called Skunk2 today... "turbo cams still under development, same for the manifold" I'm gonna make a post in the Prelude section, and i'll ask the question here...
What success stories have u had with turbo cams in H22a's? Anything to stay away from, anything u recommend? Specs if u had your stock ones redone?
Cisco93Lude
Sep 22, 2006 10:14 PM
Andryzzle
Apr 15, 2006 07:53 PM
JusT a Cx
Mar 31, 2004 08:04 AM
92lSilude
Oct 20, 2003 02:47 PM
