steps on makin a ls/vtec
Old Nov 1, 2003 | 09:08 AM
flyrice's Avatar
Default steps on makin a ls/vtec
hey, i hav a 00 si and i wanna swap it into a ls vtec
can someone help me with the steps on makin a ls/vtec... is type r heads better than the gsr heads? how much hp will i get ? thanks in advance
Old Nov 1, 2003 | 09:27 AM
hontegra's Avatar
use a gsr head you get more compression
Old Nov 1, 2003 | 09:30 AM
hontegra's Avatar
ls block with what kind of piston
Old Nov 1, 2003 | 10:00 AM
flyrice's Avatar
Default Re: (hontegra)
i'm not really good with pistons... so not sure, any advise ?
Old Nov 1, 2003 | 10:26 AM
eddiecut's Avatar
Default Re: (flyrice)
befor you start doing anything i would do a little more research, i would go with a gsr head and an itr pistons, its going to be some ok compressioin if you go with a b16 head and some ctr pistons its going to be over 12:1 comp, some ppl say you cant daily drive but some say its possible and if your not going to tune it dont even think about it....with itr pistons it brings the compression down alot so its alot safer.its really how much power you want and how much you want to spend....but do it right and dont take any shortcuts
Old Nov 1, 2003 | 10:34 AM
skribblah's Avatar
Default Re: (eddiecut)
research research research.
start with the link in my signature.
Old Nov 1, 2003 | 12:35 PM
pierrot le fou's Avatar
Default Re: steps on makin a ls/vtec (flyrice)
yeah, I highly rec you do a a good deal of research before you commit yourself to a LS/VTEC project. If you want a good basic writeup that's informative, and offers budgeting, http://www.importreview.com had a good writeup, that I used. Most of the parts can be had for cheaper of course, but it's a good place to start with if you're too lazy to search here, and want to know the basics of what's involved.
The thing can be pretty damn costly, and I get the impression that an LSVTEC/CRVTEC can be pretty unreliable if not built w/ good parts and a good builder. You should really plan things out and anticipate the costs in the respective parts before making any commitments, even if it's buying a block that seems like a good deal.
Technical advice aside (which I'm not very qualified to give), just be sure to hang around the classifields section (and maybe even groupbuycenter ) alot to look for good deals, b/c you'll end up needing a lot of parts, and every dollar you can save adds up. Also, the more time you're willing to wait, the more of a chance you'll save more, as the part you'll want most likely will show up sooner or later as a good deal.
Old Nov 1, 2003 | 02:15 PM
flyrice's Avatar
Default Re: steps on makin a ls/vtec (ronmcdon)
ohh i c, thanks alot guys
Old Nov 1, 2003 | 02:18 PM
flyrice's Avatar
well heres what i hav on my 00' si right now... Aem cold air, greedy exhuast, tokico strut and spring.. i wanna go all motor, but dun't know what to do next.. can any one help ?
Old Nov 1, 2003 | 02:19 PM
Mr Hammond's Avatar
a/k/a Jomo
Don't waste your money on a GSR or ITR head when you have a perfectly good PR3 head to build. LS block is a good start.
You can start by reading every thread in this forum.
2fast4urass
May 22, 2008 10:06 PM
93turbotegSAV
Nov 20, 2006 11:58 AM
Griffin@Camtech
Feb 22, 2006 06:15 PM
iseecivic
Feb 12, 2006 08:00 AM
chuckd05
Mar 26, 2003 08:15 AM
