Removing Climate Controle?????
Old Nov 1, 2003 | 08:54 AM
JDM 007's Avatar
Default Removing Climate Controle?????
I removed the hazard and defrost buttons, unscrewed the screws behind then,
poped the the console out, unhooked the metal wire to the heat controle **** but I still can't get the console out! It looks like the the metal wire that I detached is still hooked up to something but I can't seem to find how to get it out.
I need HELP!
Old Nov 1, 2003 | 10:07 AM
TypeR 599's Avatar
Default Re: Removing Climate Controle????? (JDM 007)
There are still 2(i think) plugs back there. there's a green one to your left that i'm sure of that you must unplug to get the console out. just peek back there and see if you see any plugs..
good luck
Old Nov 1, 2003 | 11:49 AM
SMZ GSR's Avatar
Default Re: Removing Climate Controle????? (TypeR 599)
Correct. Should be a green plug and a sort of clear/yellowish plug.
If you took the metal wire off from under the dash, then thats all you need for that. Just guide it out when you remove the console to avoid it getting bent.
Old Nov 1, 2003 | 01:34 PM
someday's Avatar
Default Re: Removing Climate Controle????? (SMZ GSR)
how do you remove the two buttons, hazzaed and defrost?
Old Nov 1, 2003 | 01:52 PM
MugenizedR's Avatar
Default Re: Removing Climate Controle????? (someday)
just take a flat screwdriver and pull under the button.
phoenix1310
Apr 12, 2011 05:53 PM
roachsboosted16
Audio / Security / Video
Jan 25, 2010 01:44 PM
85_305
Honda Civic (2001 - 2005)
Aug 26, 2009 09:44 AM
evilcivilian
Feb 12, 2008 04:09 PM
X2BOARD
Aug 21, 2002 03:39 AM
