CEL code help
I cant figure out the codes from the ecu. here's the sequence..
1..pause...1...pause...4...pause...9
then it repeats. i know the first light is for my o2 sensor, which hasnt been hooked up. i cant figure out the the other ones though. 14 and 9? i thought they went in numerical order?
thanks for the help. hopefully i can get my car fixed up w/ no more cel's
i believe what you are seeing is the ECU blink once to tell you it is working, then 1 (02 sensor) - 4 (crank angle sensor) - 9 (cylinder position sensor) - sounds like you have a bad distributor
undertheradar
Dec 4, 2004 08:03 AM
N1NjA TuRtLE
12
Jun 5, 2004 08:30 PM
