CEL Code 15 Help!
Old Nov 1, 2003 | 02:36 AM
SMZ GSR's Avatar
Default CEL Code 15 Help!
Well my bone stock 88 DX (DPFI D15B) is now throwing a code 15 which is ignition output signal.
What exactly is not working? How do I check and if necessary replace the part(s)?
Old Nov 1, 2003 | 07:35 AM
91civicEX's Avatar
Default Re: CEL Code 15 Help! (SMZ GSR)
code 15 is your coil/ ignitor. it lives in the distributor and it should be a big black plastic box. Did this problem just start or did you change something/ work on the car? a new coil is like $100 from kragen. i think you could find a whole distributor from a D15 for like $50 since so many people swap em for mpfi or new engines.
Old Nov 1, 2003 | 11:30 AM
SMZ GSR's Avatar
Default Re: CEL Code 15 Help! (91civicLX)
just started happening yesterday.
so it has to be replaced? no 2 ways about it?
Old Nov 1, 2003 | 12:18 PM
91civicEX's Avatar
check your connections there should be two screws connecting 2 wires to 2 terminals. make sure they are tight.
Old Nov 1, 2003 | 12:34 PM
Hybridize's Avatar
Sounds like your ignitor is headed south for the winter. Download a helms manual(search this forum for the link) and run through the troubleshooting flow-chart. If I remember right it can be 1 of three things, bad wire/connection, bad ignitor, or a bad ecu...
HTH
Old Nov 4, 2003 | 09:53 AM
SMZ GSR's Avatar
Default Re: (Hybridize)
bump, as i'm still gathering ideas until i have time to work on the car
Old Nov 5, 2003 | 09:50 AM
SMZ GSR's Avatar
Default Re: (SMZ GSR)
11/5/03
Old Nov 5, 2003 | 10:47 AM
project dc2's Avatar
i got this problem also .. my tach and speedo trip the **** out .. im pretty sure im due for a new coil soon =T
Old Nov 5, 2003 | 11:01 AM
SC0TT's Avatar
Default Re: (project dc2)
Have you tried resetting the ecu? I have thrown this code with both the d15 and b16, resetting the ecu got rid of the code every time.
Old Jun 7, 2005 | 05:40 PM
JDM KING's Avatar
Default Re: (SC0TT)
damn im gettin that code too, but as soon as i disconnect the battery and reconnect it the car runs fine.....wtf???????
dump3deg6
Jul 20, 2009 09:43 PM
UNDER PRESSURE
Nov 21, 2005 02:19 PM
90crvtec
Aug 19, 2005 07:19 PM
CiViC SiR
Jun 25, 2003 03:59 PM
NawTeeCRX
Jul 24, 2002 05:52 AM
