EG Sway bar Q
Old Oct 31, 2003 | 10:44 PM
Prod8421's Avatar
Default EG Sway bar Q
Hey, I'm a noob to the site... but... I have a few Q's.
I have an EG hatch... current suspension mods are as follows
Stock struts
Progress drop springs
Front Upper Strut bar
Front Lower Tie Bar
Rear Upper Strut Bar
Rear Lower Tie Bar
I have 15" Rota Grids with Toyo Proxes Fz4's 205 50 15's.
I've talked to a few people about getting sway bars..... but need some more input.
I'm thinking a 25 front, 22 rear....
I'm getting new struts, and springs, or perhaps a full coilover..... the Tein basic if i go that route.... still havn't made up my mind..
Everyone throw in their two cents on either the coilover, or sway bar..
Any advice would be greatly appreciated.
Thanks
-Chris
Old Oct 31, 2003 | 10:47 PM
The Internet Tough Guy's Avatar
Default Re: EG Sway bar Q (Prod8421)
definately get the coil-overs first. your stock struts hate you. tein basic isn't worth the money either (soft springs). if you can get the dampers with stiffer springs then go for it.
search this site for a good shock / spring combination, or a good set of coilovers.
Old Oct 31, 2003 | 10:49 PM
VX's Avatar
VX
Shocks: Koni yellows & Ground-Control Sleeves w/ Custom Eibach ERS Springs.
Swaybars: Front: 92-95 EX or Si. Rear: ITR 22mm bar w/ Beaks Kit.
Old Oct 31, 2003 | 10:50 PM
Prod8421's Avatar
Default Re: EG Sway bar Q (VX)
^^^^^^^^^^^^^^That's what Cheesefrog said when i asked him.....
Old Oct 31, 2003 | 10:52 PM
DOHCtorTHRUST's Avatar
Default Re: EG Sway bar Q (jwn7)
19mm for the rear will prolly suite your needs( really depends though).... i have the 14mm and it suites my needs... i mainly do highway driving so its perfect ffor me...
also remember to get the breaks(beaks?) kit so you dont rip your rear subframe up...but if your gonna settle for the 14mm then you dont need it
a full set of coils is definately a plus...
Old Nov 5, 2003 | 10:40 PM
yakitori's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VX &raquo;</TD></TR><TR><TD CLASS="quote">Shocks: Koni yellows & Ground-Control Sleeves w/ Custom Eibach ERS Springs.
Swaybars: Front: 92-95 EX or Si. Rear: ITR 22mm bar w/ Beaks Kit.</TD></TR></TABLE>
i agree
Old Nov 5, 2003 | 10:53 PM
Tad's Avatar
Tad
yeah, I wouldnt buy tein basics personally.
I would suggest some coilover sleeves,
koni yellows, and ground control upper strut mounts.
suspension travel is ridiculously important, especially on our eg's, where we start off raked like a freak!
Old Nov 5, 2003 | 11:49 PM
Downey's Avatar
ive got a GSR 24mm front with a ITR 22mm rear. it handles really well.. but understeers when pushed. im going to change it to a 92-95 Civic Si 21mm front and keep the rear 22mm bar. u should try the same setup. get the Beaks mounting kit, prevents or at least helps subframe tearout. i dont think you can use ur rear lower tie bar anyone tho.
Old Nov 5, 2003 | 11:53 PM
=GAME='s Avatar
or you can run w/o the front. i am currently running the rear 22mm and it handles great. im looking to invest in the ex/si front bar in the future.
Mugenkid
Suspension & Brakes
May 14, 2013 10:19 AM
EusebioSam19
15
Jul 29, 2010 07:36 PM
slow_cx
Suspension & Brakes
22
Dec 6, 2007 06:27 PM
abuck
Aug 5, 2004 01:46 PM
LudemanDan
May 29, 2002 08:25 PM
