I bought a engine!
Old Oct 31, 2003 | 10:07 PM
the_0ne's Avatar
Default I bought a engine!
I bough a b16 Sir 1 for $500(with Axles!/fly wheel). I loaded everything up in the back of my CX. It comes with a oil pressure sending unit and a aftermarket racing pully ($250)
everything is included but a tranny/shift linkage/mounts. Im currently looking for a tranny, something that is short. Im thinking about a GSR one .
What is a good tranny for a b16?(might boost down the road)
Also, Since the engine is out What should I replace on it? Should I do a light build on it? Apr Bolts/CTR internals?
here are some pics
Old Oct 31, 2003 | 10:08 PM
the_0ne's Avatar
Old Oct 31, 2003 | 10:19 PM
blackhatchy's Avatar
Default Re: I bought a engine! (the_0ne)
good luck with the install
Old Oct 31, 2003 | 10:24 PM
Ef Whore's Avatar
Default Re: I bought a engine! (blackhatchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhatchy &raquo;</TD></TR><TR><TD CLASS="quote">good luck with the install </TD></TR></TABLE>
Right! That looks like it's gonna be alot of fun.
Old Oct 31, 2003 | 10:27 PM
ace1875's Avatar
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Pump O ring (Does not come with Pump) 91302-PF0-003 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Bitch Pin Shift Linkage 91 crx si
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets (8) 90442-P30-000 94 - del sol
Valve Cover Gasket 12341-PR3-000 94 - del sol
V-TEC solenoid valve filter O ring 15825-P08-005 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose (trim) need a c clamp 19501-PR3-000 92 - integra gsr
Lower Radiator Hose (trim) need a c clamp 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
Look for parts here
Old Oct 31, 2003 | 10:28 PM
EGRhatch's Avatar
Default Re: I bought a engine! (ace1875)
cool man... good luck with the install... it does look like it will be a lot of fun
Old Oct 31, 2003 | 10:29 PM
FF-sean's Avatar
Default Re: I bought a engine! (Ef *****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ef ***** &raquo;</TD></TR><TR><TD CLASS="quote">
Right! That looks like it's gonna be alot of fun.</TD></TR></TABLE>
Old Oct 31, 2003 | 10:30 PM
ace1875's Avatar
boost or NA
choose one. cause if you want to go with the other down the road its not a simple process
CTR internalls are good for NA not for boost Short ratio Tranny is good for NA not for boost
FF-sean's Avatar
Default Re: I bought a engine! (ReaL JDM Eg6)
Old Oct 31, 2003 | 10:32 PM
sethm's Avatar
i wish i could find deals like that.
Old Oct 31, 2003 | 10:49 PM
SICKSOLSI's Avatar
only $500 thats crazy i cant believe it
Old Oct 31, 2003 | 11:44 PM
JDMs1eeper's Avatar
rebuild the bottomend and boost it. My buddy just boosted his b16a1 w/ a complely custom kit that only cost him around $230 to make. He used a 16g and everything was completly gettoh, lol but **** it, its VERY fast. He's runnign 10psi haha
Get a GSR tranny
Dont hop on the N/A bandwagon, Dont get on the Brandname one either
Lets start a new one and Gettoh rid everything! Be gettoh like us!!
::lease dont listen to me... its 4am, holloween.. yeah :::
..goodnight
Old Nov 1, 2003 | 12:42 AM
binkster's Avatar
wow .. your ambitious.. good luck
Old Nov 1, 2003 | 12:43 AM
binkster's Avatar
wow, your ambitious, good luck with the install
Old Nov 1, 2003 | 05:47 AM
KiDSoL's Avatar
Default Re: I bought a engine! (binkster)
Sweet, are you putting it all back together yourself?
Old Nov 1, 2003 | 06:22 AM
WAFFLES's Avatar
Default Re: I bought a engine! (KiDSoL)
Dont get a GSR tranny. I have one on my B16A. It's not short enough. For a b16, it needs either a B16 tranny or ITR/CTR tranny. Longer gearing sucks when you have no torque. Whether you're turbocharged or not, stick with the shorter gearing. Shorter gearing is quicker acceleration.
Old Nov 1, 2003 | 07:23 AM
Happyman's Avatar
Default Re: (Kikomon)
Atleast it came with an oil filter!
Old Nov 1, 2003 | 09:42 AM
PHiZ's Avatar
Default Re: (eh6turbo)
sorry, what chassis is it going in? Cable or Hydro?
-PHiZ
Old Nov 1, 2003 | 09:44 AM
b18b_eg's Avatar
good luck finding all the right parts...
Old Nov 1, 2003 | 10:06 AM
G U E C O's Avatar
Default Re: I bought a engine! (WAFFLES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">Dont get a GSR tranny. I have one on my B16A. It's not short enough. For a b16, it needs either a B16 tranny or ITR/CTR tranny. Longer gearing sucks when you have no torque. Whether you're turbocharged or not, stick with the shorter gearing. Shorter gearing is quicker acceleration.</TD></TR></TABLE>
agree
Old Nov 1, 2003 | 10:11 AM
bartek_b's Avatar
Old Nov 1, 2003 | 10:15 AM
the_0ne's Avatar
Default Re: (PHiZ)
1994 civic cx
hydro, ill go with a b16 tranny
also p30 ecu
Old Nov 1, 2003 | 10:41 AM
blackANESE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ace1875 &raquo;</TD></TR><TR><TD CLASS="quote">Short ratio Tranny is good for NA not for boost</TD></TR></TABLE>
Shorter tranny=faster acceleration wether it be boost or N/A.
Old Nov 1, 2003 | 11:08 AM
Ekizzle's Avatar
Old Nov 1, 2003 | 12:10 PM
GQ Cowboy's Avatar
Default Re: I bought a engine! (AREA 51)
Its going to be a loooooooong night(s).
