questions - modifying an R exhaust and header/cat concerns for my gsr
Hey guys, I finally got my type R exhaust. Everything looks great too.
Ok, for one I've read that I need to extend the b-pipe like 4" right behind the cat.
I also read (and noticed since i have it now), that right at the flange at the front of the b-pipe, the pipe necks down to 2". So, I need to whack that off, and add some 2.25" pipe and a new flange.
My plan was to take my stock b-pipe off and have my dad, or a muffler shop, or whoever make the R b-pipe look exactly like the stock b-pipe.
However, I was trying to think of the long run... I have a 94 gsr and currently the exhaust is completely stock. One gripe of mine - I hate exhaust work... grr... it sucks. Another gripe - I hate doing work over and over again. I've already had a complete aftermarket exhaust on my car - header/testpipe/catback and it was too loud and ricey (DC 4-2-1 2pc, 2.25" resonated TP, Greedy Evo if anyone cares).
I guess what I'm saying is should I go ahead and put a high flow cat on now? If so, should I get a 2.25" inlet and outlet?
also, If I decide to get a Kamikaze header in the future (thats the best for a jrsc'd car, right?), it will have a 2.5" outlet.. will that cause probs if everything else is 2.25"?
I was also thinking... running rich will clog up the cat, right?
Well, if I put on a high-flow cat and I'm still running rich, wont I just clog it up too?
should I go the testpipe route? im OBD1
so no CELs
if i do go testpipe... and make it 2.25" and then later on if i got the header thats 2.5" collector.. then what? just put a reducer in front of the testpipe? or can you just butt the flanges together without probs?
also, are catco cats good?
so no CELsif i do go testpipe... and make it 2.25" and then later on if i got the header thats 2.5" collector.. then what? just put a reducer in front of the testpipe? or can you just butt the flanges together without probs?
just get the ITR JDM header, carsound cat. this is the same setup i have..although not installed yet....all these will bolt directly into one another.
Well i was going to go with the Kamikaze header because the best header for JRSC'd cars.
i forgot to mention that my 94 gsr has a JRSC @ 6psi
you can get the kamikaze...into a car sound cat which can bolt into the type r exhaust...
so for now, just put on the exhaust, then when you get the header, get the high flow cat with it
anyone know where i can get one of the flanges i'll need to weld back onto my b-pipe?
the flange now is 2"... i'll need one thats 2.25".
is there any specific size? can i get it anywhere?
