what parts can i use.....
Ok- i did a search (2hrs worth)
What parts can i use from a eg hatch (Manual) to convert an EK hatch (auto). I am doing complete swap and need to convert to 5 speed. I know the obvious ****-
WHat i need to know is like master cylinder, lines, pedals..will these all work? Shift linkage from an eg won't right?
HELP!!
Thanks~
HELP!!
Thanks~
I think the only things that are different are all the clutch lines and hard lines going to the slave. But i have used 94 teg lines on ek's before. you just gota be creative, the linkages should all be the same though D series. somebody correct me if I am wrong.
1999AZhatch
Jul 23, 2018 11:07 AM
turbo97coupe
Jan 15, 2009 06:40 AM
ClubDownforce
Jan 19, 2006 01:11 AM
