Honda Bond Question
Old Oct 31, 2003 | 03:16 PM
civichbb18c's Avatar
Default Honda Bond Question
Anybody have a price on this stuff when purchased from a dealer?
Old Oct 31, 2003 | 03:22 PM
TrickHonda98's Avatar
Default Re: Honda Bond Question (civichbb18c)
be a little more specific.
Old Oct 31, 2003 | 03:24 PM
aw1234dude's Avatar
Default Re: Honda Bond Question (TrickHonda77)
Ive heard hondabond is made by the same company that makes ultra grey. I have always used ultra grey and ultra black on all of my projects. Works just the same. You can get the stuff from any auto parts store too for about 6 bucks a tube.
Old Oct 31, 2003 | 03:26 PM
Default Re: Honda Bond Question (aw1234dude)
thanks, i got a cam seal that needs to be installed.
Old Oct 31, 2003 | 03:41 PM
MPower332TI's Avatar
Hondabond is like 12 bucks from the dealer but and gasket sealer will do the trick as long as its felxiable.
Old Oct 31, 2003 | 05:31 PM
pro1342's Avatar
Default Re: Honda Bond Question (jDmDxTuRd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDmDxTuRd &raquo;</TD></TR><TR><TD CLASS="quote">Hondabond is like 12 bucks from the dealer but and gasket sealer will do the trick as long as its felxiable. </TD></TR></TABLE>
Old Oct 31, 2003 | 05:40 PM
EG2 SiR's Avatar
Default Re: Honda Bond Question (pro1342)
I've heard, that permatex™ and Hondabond™ are the same exact thing but I've compared them and they are slightly different in colors so I doubt that they are manufactured by the same co. Each work well. I like Hondabond™, but Permatex ultra gray works just as well. HB = $12-16 a tube, Ptex = 4.99-6.99 a tube.
Old Oct 31, 2003 | 05:51 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Honda Bond Question (EG2 SiR)
anything but permatex BLUE.
ultra grey is theb st other than GMS.
gms is general motors sealer. iti s hands down the best.
IMO. he hee. but it holds up really well.
Old Oct 31, 2003 | 06:05 PM
dantastic's Avatar
you're supposed to put sealant on the cam seal? whoops. i dont see any oil leaking...
Old Oct 31, 2003 | 06:08 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aw1234dude &raquo;</TD></TR><TR><TD CLASS="quote">Ive heard hondabond is made by the same company that makes ultra grey. I have always used ultra grey and ultra black on all of my projects. Works just the same. You can get the stuff from any auto parts store too for about 6 bucks a tube. </TD></TR></TABLE>
Correct. Just spend the $3 or $4 on the Ultra Grey sealant (grey color) and use that... same **** as buying Hondabond from the dealership, only at a fraction of the price.
Old Nov 1, 2003 | 05:43 PM
Mista Bone's Avatar
D Tranny Guru
Hondabond and UltraGrey are different.......
Hondabond cleans up easy with Autozone carb cleaner, Tolulene based.
Ultragrey is unaffected by the carb cleaner.
I use the Ultragrey on all the tranny I rebuild, never a leak.
Old Nov 1, 2003 | 05:47 PM
Plan B's Avatar
Default Re: Honda Bond Question (Mista Bone)
hondabond is cheaper at motorcycle shops for the same stuff.
Old Nov 1, 2003 | 05:49 PM
GimpyAccord's Avatar
Default Re: Honda Bond Question (Plan B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plan B &raquo;</TD></TR><TR><TD CLASS="quote">hondabond is cheaper at motorcycle shops for the same stuff.</TD></TR></TABLE>
Are you talking about Yamabond (what Yamaha sells)? I just use ultragray (aka #999). I like honda and all, but I ain't payin' the H premium for their oils/sealants.
Old Nov 1, 2003 | 05:52 PM
2000CX's Avatar
Default Re: Honda Bond Question (GimpyAccord)
can the ultra grey also be used on the valve cover gasket?
Old Nov 1, 2003 | 06:00 PM
Default Re: Honda Bond Question (2000CX)
I use it on the corners of the cam caps to keep those dry, but otherwise you shouldnt need it
Old Nov 1, 2003 | 08:50 PM
BatuKing's Avatar
I use Permatex Ultra Copper or Permatex The Right Stuff.
The right stuff is more adhesive and works for oilpan gaskets and other items where you need to make a liquid gasket.
Old Nov 1, 2003 | 10:49 PM
Mr. Badwrench
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">you're supposed to put sealant on the cam seal? whoops. i dont see any oil leaking...</TD></TR></TABLE>
not really, it is advised to put it on the corners of the caps. if you put it on the seal, it will pop out. i put them in with grease on the lip, and dry on the outside.
VegasInvasion
Nov 13, 2008 11:11 PM
ChargedSI
Honda Civic (2006 - 2015)
Sep 4, 2008 01:48 PM
xerox445
Dec 30, 2003 03:23 AM
.RJ
May 11, 2003 05:04 PM
Fuster_Cluck
Mar 26, 2003 11:06 PM
