how many miles are too many to turbocharge?
Old Oct 31, 2003 | 02:42 PM
dropped like its hot's Avatar
Default how many miles are too many to turbocharge?
my d16's got 107k miles. they arent abused miles at all. with good fuel management and tuning will i be ok? its my daily driver, wouldnt run over 8 psi. stock engine too.
Old Oct 31, 2003 | 02:51 PM
JICEK9's Avatar
Default Re: how many miles are too many to turbocharge? (nick123)
do some more research. with some right tuning you should be fine at least up to 6lbs.
Old Oct 31, 2003 | 02:53 PM
30psi Teg's Avatar
Its not so much milage as it is overall engine performance. Like does the engine smoke?? use coolant??? burn oil?? Do a compression check on the engine and even a leakdown test if you want to be safe. If these are good and the motor seems solid then you should be fine. Hondas are built real well and stay storng if they are taken care of. I tore apart an engine w/ 130k on it and it was in excelent shape.
Old Oct 31, 2003 | 02:54 PM
Fkned's Avatar
Default Re: how many miles are too many to turbocharge? (30psi Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psi Teg &raquo;</TD></TR><TR><TD CLASS="quote">Its not so much milage as it is overall engine performance. Like does the engine smoke?? use coolant??? burn oil?? Do a compression check on the engine and even a leakdown test if you want to be safe. If these are good and the motor seems solid then you should be fine. Hondas are built real well and stay storng if they are taken care of. I tore apart an engine w/ 130k on it and it was in excelent shape.</TD></TR></TABLE>
Old Oct 31, 2003 | 02:57 PM
Default Re: how many miles are too many to turbocharge? (fkned)
hey thanks for the quick responses!! i guess i get a for not searching lol, i didnt think that it would have come up with anything, now i know
Old Oct 31, 2003 | 08:05 PM
RedTegLS's Avatar
I have 125k on my 95 teg and I am going turbo next week. I will let you know then
Old Oct 31, 2003 | 08:50 PM
PHiZ's Avatar
130k D16z6 turbo here, but I don't daily drive it.
But it runs strong...
also, what is the difference between compression check and leakdown?
-PHiZ
Old Oct 31, 2003 | 09:52 PM
J-Brooks's Avatar
Default Re: how many miles are too many to turbocharge? (PHiZ)
I say do it. I am fixing to turbo my LS with 224,XXX miles! Good luck with your setup!
Old Oct 31, 2003 | 10:36 PM
lazerus's Avatar
Default Re: how many miles are too many to turbocharge? (Type R Driven15)
It's not the mileage, it's the Quality.
If the motor is in good condition and has 200,000 miles you could boost it..
if the motor is in poor to fair condition and has 80,000 miles on it, it could blow if you boost it.
it all depends on how well the motor has been treated, and what condition it's in.
p0gi's Avatar
my wifes car has 179k and has been turboed since about 140k, and is a daily driver.
Old Nov 1, 2003 | 12:41 PM
Fkned's Avatar
The difference between comp and leakdown is basicily that a leakdown shows you where and how much the cyl is leaking,where as a comp test only tells you what the cyl will hold.When u do a leakdown listen for where the air is leaking from,if from the dipstick or breather then the rings are bad,int mani or headers=bad valve job or bent valve.Leakdown will also tell you the condition of the cyl by having a gauge that states the amount of leakage in % terms.
Old Nov 1, 2003 | 12:52 PM
NuclearB18B's Avatar
turbo since 125k. only been a few thousand miles.
Old Nov 1, 2003 | 01:12 PM
gdrum's Avatar
Default Re: how many miles are too many to turbocharge? (ha illuminato un)
my friend just turboed his 93 dx with 158k miles....pulls and runs fine and its a daily driver
Old Nov 1, 2003 | 04:18 PM
Default Re: how many miles are too many to turbocharge? (gdrum)
ahh, its good to hear all the positive results!! may i ask what you guys are using for fuel management?
Old Nov 1, 2003 | 04:27 PM
Deluzional's Avatar
turboed at 105xxx now 112xxx..daily driven. AFC hack here
Old Nov 1, 2003 | 04:46 PM
ross1459's Avatar
i just put in my turbo at 138k mi
Old Nov 1, 2003 | 09:37 PM
J-Brooks's Avatar
Default Re: (ross1459)
I am doing Hondata s200 w. boost. Inline Walbro Fuel Pump 255 High Pressure, and RC 550cc Injectors.
Old Nov 1, 2003 | 09:48 PM
p0gi's Avatar
Default Re: (Type R Driven15)
emanage , 255 walbro, 370 injectors
jp4543
Feb 3, 2016 09:03 AM
bp_pow
Jul 2, 2014 07:27 AM
themiz816
Apr 3, 2013 09:49 PM
Griff
Jul 5, 2006 06:47 AM
90hbvtec
Dec 13, 2005 12:59 PM
