My Horn Doesn't work!!!
Old Oct 31, 2003 | 01:43 PM
bossman032's Avatar
Default My Horn Doesn't work!!!
OK here is the problem it works sometimes it doesn't sometimes.
Today a Crack Head nearly hit me I hit my horn and it didn't even work lol
Wtf can be wrong fucken **** works sometimes and doesn't some times like it has a mind of its own its hell raining today maybe that's why It don't work..
anyways how much are air horns.. I want to scare the **** out off the people to cant drive!!!
Old Nov 2, 2003 | 01:47 PM
bryan305's Avatar
Default Re: My Horn Doesn't work!!! (bossman032)
before you go buying air horns, you need to figure out the problem. It sounds like an electrical prob. I'd try disconnecting the horns from the wiring, then running voltage to them directly to make sure they work. If those are fine ( most likely they are) then use a multimeter to test for voltage in the wires when someone else presses the horn button. If you get intermittent voltage you get to have the fun of tracing it back to the horn switch in the steering wheel. Could be the switch is just old and corroded and needs to be cleaned up.
Old Nov 2, 2003 | 02:24 PM
Vinceg99's Avatar
Default Re: My Horn Doesn't work!!! (bryan305)
I would say the first and easiest thing to do is to pull off your steering wheel and look to see if the wire under there is loose/partially disconnected.
Old Nov 2, 2003 | 02:40 PM
Hcivic88's Avatar
Default Re: My Horn Doesn't work!!! (Vinceg99)
either what vince said, or pull off the front bumper and make sure the connections are fine down there, i've had those wires corrode on me before, but I didnt find out till the bumper was off, i just touched the wire and it broke right off... I was wondering why only one horn would work, lol, so before u go buying air horns, have a look at your wiring. after you fix the wiring, then you can buy the air horns
Old Nov 2, 2003 | 03:10 PM
HatchBox's Avatar
Skoobie no more...
Default Re: My Horn Doesn't work!!! (Hcivic88)
check your fuse's
Old Nov 2, 2003 | 03:16 PM
bossman032's Avatar
Default Re: My Horn Doesn't work!!! (ind3ciso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">check your fuse's </TD></TR></TABLE>
Fuses are fine. Does it have to do anything with the stereo wires?
Cause some thief's took my deck and maybe fucked up the stereo wires will that cause it not to work it sometimes works sometimes dosent
Old Nov 14, 2003 | 07:19 AM
cascaritas's Avatar
my horn dosent work either, i checked the actual horn and it works but when i checked the plug i used the chassy for a groung and the test light lights up when no one is pressing the button but whe itryed it with someone pressing the button and the ground from the plug nothing. i get u cant help getting pissed off when some one cuts u off and and u go for the horn and nothig
Old Nov 14, 2003 | 09:44 AM
bossman032's Avatar
Default Re: (cascaritas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cascaritas &raquo;</TD></TR><TR><TD CLASS="quote">my horn dosent work either, i checked the actual horn and it works but when i checked the plug i used the chassy for a groung and the test light lights up when no one is pressing the button but whe itryed it with someone pressing the button and the ground from the plug nothing. i get u cant help getting pissed off when some one cuts u off and and u go for the horn and nothig </TD></TR></TABLE>
hell yea u know how I feel
well some good news I wired up my deck sony and now everything works fine no problems I test it every day and it works. so I am gussing it had something to do with the sterio wires looks like maybe it wasn't getting power or something!!
Old Nov 14, 2003 | 03:10 PM
RonaldCRX's Avatar
Default Re: (bossman032)
Sounds like you have a problem with wires somewhere, once you figure it out ..
i bought these Hella Supertones from Griots for my CRX - they are crazy loud. I initially installed them just replacing the stock ones and they were ok but i just re-hooked it up using the relay that comes with them and getting power from the battery direct and YOW .. loudness to scare off the most cracked of crack heads 118dB .. around $70 buxes.
http://www.griotsgarage.com/ca...77573
integra_101
Oct 23, 2013 11:43 AM
B00stedEh3
Aug 1, 2010 07:28 PM
LAO
Oct 1, 2007 11:16 AM
robotosan
Acura TL, RL & ZDX
Sep 1, 2007 12:34 PM
blkgsr03
Jul 15, 2003 09:32 PM
